Wiring LED bar to high beam
Discussion in 'FBC Harness Solutions' started by Adamkrol20, Jun 24, 2023.
  1. Jun 24, 2023 at 9:19 AM
    Adamkrol20
    Adamkrol20 [OP] Member
    Adam
    2023 Tacoma limited
    Nothing
    Good morning. I'm looking for a plug and play T harness to hook the relay from my DD stealth bar to my high beams, when they come on, the light bar will come on. Is this already an option or is there something you guys can make for me?
  2. Jun 24, 2023 at 9:35 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    My LED T harness switch-pros option is what you want. Though if you have zero interest in a DRL + park feed for grille lights or backlight then you can get a high beam only version. I’m not sure what I have listed but that’s the basic item and pricing.
  3. Jun 24, 2023 at 9:39 AM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    What switch do you have for the light bar? The one currently turning it on and off?
  4. Jun 24, 2023 at 11:52 AM
    Adamkrol20
    Adam
    2023 Tacoma limited
    Nothing
    Yea just the toggle switch. I'm taking it off my truck and putting it on my father and law and he wants it to just come on when the high beams come on automatically. I want everything to work as intended like normal. No extra anything. Just the LED bar to come on when the high beams auto come on at night.
  5. Jun 24, 2023 at 12:09 PM
    Puppypunter
    Johnny
    2019 Black SR
    What year and headlights are on the father in laws truck?
  6. Jun 24, 2023 at 12:14 PM
    daveeasa
    David
    PNW
    Ah, yes, my goof, I assumed OP’s truck.
  7. Jun 24, 2023 at 12:20 PM
    Puppypunter
    Johnny
    2019 Black SR
    Not a bad assumption given the first post :)
    @Adamkrol20 is what you will need to do is route a wire from the positive side of the high beam to the relay coil. If you can tell us more about the relay and the truck, either Dave or I should definitely be able to get you taken care of.
  8. Jul 7, 2023 at 6:42 PM
    Adamkrol20
    Adam
    2023 Tacoma limited
    Nothing
    Sorry guys I lost track of getting this done with everything going on. I will get all the details of his truck tomorrow. I'm really hoping to have y'all make a direct connection with extra wires to tie in the switch for the relay. I'll get you all the info tomorrow. Thank y'all!
  9. Jul 10, 2023 at 10:37 AM
    Adamkrol20
    Adam
    2023 Tacoma limited
    Nothing
    My father in laws truck is a 2021 SR with halogen headlights.
  10. Jul 10, 2023 at 10:56 AM
    daveeasa
    David
    PNW
    Cheapest option for that is an H9 extension harness. I can do the same basic thing too.
  11. Jul 10, 2023 at 12:03 PM
    Adamkrol20
    Adam
    2023 Tacoma limited
    Nothing
    Can you make like a T harness I can just plug and play in between the headlight and wiring and just tie in the light bar to whatever wires you have for it open? Don't wanna splice into anything on my own
  12. Jul 10, 2023 at 2:34 PM
    daveeasa
    David
    PNW
    I can but is there a connector for the DD harness input? And rough distance from high beam bulb.
  13. Jul 10, 2023 at 2:38 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Just beware that may not be road legal depending on where you are. Here you can't use light bars on the road and technically they're supposed to be covered up (although I've never seen one covered up).
    Tacospike and daveeasa like this.
