Wiring led light bar
Discussion in '2nd Gen. Tacomas (2005-2015)' started by baldy54, Aug 16, 2019.
  1. Aug 16, 2019 at 5:38 PM
    baldy54
    baldy54 [OP] Well-Known Member
    Orlando, FL
    06 Prerunner SR5
    Trying to install a led light bar on my Tacoma and not having any luck. The problem is the switch light stays on all the time. I have a mictuning switch and there wire harness. Can any tell me if I wired this switch right if not what do I need to get it right.
    So I have black on black wire, green blue wire on white wire, red/yellow next green wire hooked up to blue, and the other red yellow wire next to black wire is hooked to a add a fuse in the tail light fuse box.
    When all the wires are hooked up and add power the blue light bar symbol stays on all the time. How do I get that only come on when I press the switch for the light bar to come and off? The bottom letters only come on when when I turn on the tail lights..
    Thank you for you help.
  2. Aug 16, 2019 at 9:10 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    googling the mictuning schematic this is what I see. You want the green wire to connect directly to the battery through an in-line fuse or add-a-fuse, the red1 to be connected to your light bar or relay, red2 connect to the truck's green tail light wire circuit which supplies +12V when the headlight switch is on tail or headlight mode. The black goes to ground and provides switch closure for the "LED light bar" icon light on the switch as well as ground for the light bar icon on the switch. Not sure where you tapped into the trucks wiring but hopefully this helps.
    PzTank likes this.
  3. Aug 17, 2019 at 4:51 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  4. Jan 29, 2020 at 2:41 PM
    jarebear74
    jarebear74 Bar down or it doesn’t count
    Colorado Springs, CO
    2010 OR DCSB
    Did you ever find a fix for this? Am looking to get a couple of their 12awg or 14awg harness and switch.
