Wiring LEDs in Front Light Bar, Rock Lights, Puddle Lights, Rear, Footwell, Bed, Map and Dome
Discussion in 'Lighting' started by pc3coyote, Nov 18, 2017.
  1. Jan 24, 2018 at 1:25 AM
    redrelyt12
    redrelyt12 Well-Known Member
    Tyler
    2016 Tacoma TRD Sport DCLB
    Derped TRD Sport Grille BAK Revolver X2 Tonneau Cover mattgecko Waterproof LED Hood & Bed light kits Southern Style OffRoad Slimline Hybrid Front Bumper Baja Designs 20" S8 Light Bar Smittybilt X2O-10 Winch Blue 3/4" Shackles
    Looks great, clean install, very bright!
    pc3coyote[OP] likes this.
  2. Jan 24, 2018 at 3:52 AM
    pc3coyote
    pc3coyote [OP] www.pc3coyote.com
    Paul
    SoCal
    17 BBP Sport DCSB 4x4
    Thanks! I’m going to ponder this a little further before I do haha
    Thanks! I appreciate it!
  3. Jan 24, 2018 at 10:44 AM
    techman993
    techman993 Well-Known Member
    Allen
    Pittsburgh, PA
    2018 Cement Tacoma TRD OR
    Tinted Windows B-pillar vinyl delete Tyger Step-Tubes Tailgate decals (Thanks @rrentop!) Boss 2" lift 285/70/R17 Nitto Terragrapplers TRD PRO Rims
    be taking a gander at this this weekend. thanks!
  4. Jan 24, 2018 at 10:49 AM
    pc3coyote
    Paul
    SoCal
    Happy to help!
  5. Jan 24, 2018 at 10:52 AM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    What the heck are you using a 30A fuse on the rock lights for?
  6. Jan 24, 2018 at 12:49 PM
    pc3coyote
    Paul
    SoCal
    I used the in-line fuse (from relay to positive terminal of battery) that came in the supplied harness. I don’t recall the fuse size. The OP had links to all supplies that I used.
  7. Jan 24, 2018 at 2:05 PM
    OdiN1701
    Colorado
    Oh well your diagram had it as 30A and those lights draw like 3A :p
  8. Jan 24, 2018 at 2:45 PM
    pc3coyote
    Paul
    SoCal
    Ah yeah I think I put that just because that’s what the harness comes with. Definitely overkill and you can definitely use a smaller one if you’re not using the prebuilt harnesses!
  9. Jan 28, 2018 at 11:47 AM
    Old_Guy
    Old_Guy Well-Known Member
    2017 Tacoma Off Road DCSB
    I wired my Rigid Ignites into the reverse light wiring which I installed into the tubes on my SnugTop XTR. I also installed a Rigid SRM backup light kit in the bumper.
    I moved the turn signal to the reverse light socket and now have the full "C" as tail and brake lights.
    The Rigid Ignites come on when in reverse and the switch in the cab turns all four on. You will need to install a diode to keep from back feeding. Some get weirded out when folks start talking about diodes, but they are very easy to install. I used solder seal connectors for the wiring and posi-tap connectors to tap into existing wires.
  10. Jan 28, 2018 at 1:07 PM
    pc3coyote
    Paul
    SoCal
    Looks great! Do you happen to have more info on what diodes you used and how you wired them in for the less electrically-inclined folks like myself? Right now I just have them come on via a switch in the cab.
  11. Jan 28, 2018 at 3:50 PM
    Old_Guy
    I'm assuming you want the Rigid lights to come on when you put it in reverse and when you hit the switch. But don't want the factory reverse lights to come on when you press the switch.
    I use Schottky Diodes, they are very fast clamping and have a very small forward voltage drop. These are 10 amp which are more than enough for backup lights.
    https://www.amazon.com/Electronics-...4&sr=1-1-spons&keywords=Schottky+Diodes&psc=1
    Current through a diode can only flow from the anode to the cathode, which explains why it’s important for a diode to be connected in the correct direction. Physically, every diode should have some sort of indication for current flow. Usually the diode will have a line near the cathode pin, which matches the vertical line in the diode circuit symbol. So just put the gray circle on the side you want blocked.
    Make up wires long enough to reach from the reverse light positive wire to the positive wire of the Rigid lights and install the diode in them. I did both sides because I wanted to do the wiring behind the tail lights (easy to get to). I use solder seal connectors for my wiring. Easy to use and makes a very solid connection. Then I put 3:1 marine dual wall, adhesive lined, heat shrink tubing over all of it. That's overkill but I don't want any moisture getting to the connections.
    https://www.amazon.com/Connectors-S...&sr=1-32&keywords=solder+seal+wire+connectors
    https://www.amazon.com/MulWark-130p...179909&sr=8-9&keywords=3:1+shrink+tubing+wrap
    Once you have the wire with diodes tap into the positive wire of the reverse lights and run it to the positive wire of the Rigid lights. (Remember or mark which way current is flowing). I use posi-tap connectors for the taps. They are easy to use and make a very solid connection. You can also reuse them.
    https://www.amazon.com/Posi-Tap-Con...d=1517181870&sr=1-5-catcorr&keywords=posi-tap
    Doing this will make your Rigid lights come on with your reverse lights but prevent any current flowing back to your factory reverse lights and ecu when you hit the switch.
    It's really easy to do, just take your time and you will be fine.
  12. Feb 1, 2018 at 9:49 AM
    Toyotico
    Toyotico Well-Known Member
    Jonny
    Cartersville, Georgia
    2017 Silver Tacoma 4x4 dclb
    Subd for future brightness. Thanks for writing this up!
  13. Feb 10, 2018 at 5:46 AM
    Pat3002t
    Pat3002t Well-Known Member
    3rd gen SR 2.7 5MT
    Liking these Rigid Ignites. If only wired into oem reverse lights with no switch whatsoever diodes are unnecessary right? I have enough swithched aux lighting. That's why I'm interested in the most basic use for these little gems.
    Also any reason for using the diffused over flood for max reverse lighting in darkest areas. Easier on the eyes?
    pc3coyote[OP] and DubfromGA like this.
  14. Feb 10, 2018 at 6:23 AM
    pc3coyote
    Paul
    SoCal
    Looks great!
    Thanks for the detailed reply! Super helpful! Will attempt this soon!
    No problem, good luck!
    No, I don’t think you’d heed a diode or even a relay. These pull so little you could simply splice into the pos/neg of the tail lights similar to a shell third brake light. Much, much simpler install with very little wiring!
    Diffused are sold as a set for reverse lights, versus buying individually, so you can get them a lot cheaper than the individual floods or spots. They are plenty bright. If you use them with your reverse lights, they aren’t as intense or shoot light as far as the other options which is nice so you don’t blind other drivers (parking lots etc)
    Pat3002t[QUOTED] and KTJO 4x4 like this.
  15. Feb 10, 2018 at 9:00 AM
    #35
    Old_Guy
    That's correct, you can wire the Ignites into the reverse lights with no problems. They draw very little current. That's the way I had mine wired for a couple months before I added the SRM's and they worked fine. I used the diodes so all of them didn't come on when in reverse.
    I like the diffused over flood for backup lights. Even though the floods are a wide beam pattern they still leave dark areas in the camera. The diffused light up everything.
  16. Feb 12, 2018 at 4:09 AM
    #36
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Nice write up man and nice truck i love that color and the little things you have done.
  17. Feb 12, 2018 at 4:16 AM
    #37
    pc3coyote
    Paul
    SoCal
    Thanks, Jacob!
    ready6delta[QUOTED] likes this.
  18. Feb 25, 2018 at 3:45 AM
    #38
    DubfromGA
    DubfromGA Well-Known Member
    Greg
    2017 Black SR5 4WD
    This is of great interest to me. I'd really like to increase light output when in reverse.
    It'd be cool to see how it looks through your reverse-camera, too. Hopefully the image is enhanced a great deal, too.
    pc3coyote[OP] and ready6delta like this.
  19. Feb 25, 2018 at 1:57 PM
    #39
    Old_Guy
    I'll try to get some pictures of the backup camera screen tonight. It makes a huge difference. After putting the shell on I found the oem reverse lights to be almost useless. It helped when I replaced the oem reverse bulbs with leds.
    But when I added the Rigid Ignites to the camper shell it made a huge difference. Part of that is the lights being mounted high on top of the shell, the Ignites with the diffused lens lights up everything.
    Then I moved the turn signals to the reverse lights and didn't know if that would make a difference not having the oem reverse lights any longer. I was happy to see not having the oem reverse lights made very little noticeable difference.
    When I turn on the Rigid SRM lights in the bumpers it's almost too much light if objects are very close.
    pc3coyote[OP] and KTJO 4x4 like this.
  20. Mar 9, 2018 at 5:59 PM
    #40
    Triggerhappy
    Triggerhappy Well-Known Member
    Jake
    Denver
    2019 T4Runner ORP
    It never ends
    Subd
