Wiring LED's to turn on with dome light.
Discussion in 'Lighting' started by aleok, Feb 21, 2010.
  1. Feb 21, 2010 at 6:46 PM
    aleok
    aleok [OP] Active Member
    Anyone can help me wire some LED's to turn on when the dome light turns on when the doors open? There must be a wire i can tap into correct?
    Thanks!
  2. Feb 21, 2010 at 9:15 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
  3. Feb 23, 2010 at 2:08 AM
    aleok
    thanks. In his diagram... what/where is the IGN 12v? do you know the color and location? Also what is a "jumper"? do i just connect the 87, 30 and 85?
  4. Feb 23, 2010 at 3:32 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    k thats the part that i did a little differently. i didn't use a jumper and my relay is a bit different. i gotta go look again lol.
    the IGN 12V is so you can turn it on on command using a switch. this is the part i did differently. its basically just another route for your power to get to your lights, overriding the relay.
  5. Feb 23, 2010 at 3:56 PM
    aleok
    ok, can you let me know when you recall?
    also where is the IGN 12v wire?
  6. Feb 23, 2012 at 11:26 AM
    Mikey09
    Mikey09 Member
    can some one tell me how to connect led to dome light? i want when i unlock or open door the led turn on same time as dome light.I open the dome light yesterday it have 3 wire in there i am not sure which one to connect to.
    thanks
  7. Apr 5, 2012 at 5:10 PM
    abec34
    abec34 New Member
    california
    09 sr5 prerunner
    i connected my led lights to my door trigger so they will turn on once the door opens but its not giving off enough power the lights are very dim how come?
  8. Apr 5, 2012 at 5:15 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    i've changed it up since then.
    the door triggers are negative charge, so i used a three way switch to switch the grounds instead of using a relay.
    i have a writeup buried somewhere in my build thread.
