wiring LED's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jake slatnick, Dec 24, 2009.
  1. Dec 24, 2009 at 4:41 PM
    jake slatnick
    jake slatnick [OP] Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    so i want to wire a led strip on my dashboard (under my stereo) but i dont have a voltage meter. where would i find a 12v power outlet behind my dashboard?
    any help would be very much appreciated
    thanks
  2. Dec 24, 2009 at 4:47 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    do you want constant power or accesory power. you should at the very least get a test light for 12v electrical work. they are super cheap and will save you headaches
  3. Dec 24, 2009 at 4:58 PM
    SManZ
    SManZ el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    Sounds like you need a wiring diagram from the service manual if you're not going to get a multimeter. You can get them for around $12 at Wal-Mart or Advance Auto and they are a great tool to have.
    If it were me I would tap power off of the 12V accessory outlet/cigarrette lighter, or the power wire for the radio lighting. IIRC the radio lighting is tied into the dimmer switch so the dimmer may affect your LED strip. Once you find power you can run your own ground.
  4. Dec 24, 2009 at 5:03 PM
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    you could use an add a fuse imo. its really easy and no need to splice the wires.
