Wiring lights to turn on with truck, but turn off with hi beams
Discussion in '1st Gen. Tacomas (1995-2004)' started by Colchicine, Aug 26, 2019.
  1. Aug 26, 2019 at 10:12 AM
    Colchicine
    Colchicine [OP] Well-Known Member
    Newport News, Virginia
    | 2000 | 2.7L | 4x4 | Auto | Standard cab |
    I have an LED light bar with a SPST relay and a switch, so the light can only be switched on when the truck is running. In order to pass state inspection, I have to have it wired so that it will also automatically turn off when the high beams of the headlights are on.
    In other words: I need the relay to be NO, and closed when the truck is running. I then need a second trigger, from the high beams, to then open the circuit.
    Doing searches on this topic will almost entirely give me results for people wanting accessory lights to be turned on WITH the high beams. I can figure out a way to do this with two relays, but I asked an electronics friend about this thinking they make a device that does this already. He suggested a DPDT relay, and I bought one.
    But I'm looking at it and I don't think it will do what I want. I don't see how it will accept two different triggers. Instead, it's best for reversing polarity.
    What do I need to do to have this light bar work with two different triggers?
  2. Aug 26, 2019 at 10:54 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    you want the lightbar to be on whenever the truck is running, and turn off, when the hi beams are switched on?
  3. Aug 26, 2019 at 10:55 AM
    Colchicine
    Correct
  4. Aug 26, 2019 at 10:59 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Easiest method would be to use the lowbeam circuit as a source of power for your switch to activate the LED light's relay. Your low beams are switched off when the hi beams are on. This would mean you would need to have at least your headlights low beam on in order to use your LED light.
    Colchicine[OP] likes this.
  5. Aug 26, 2019 at 11:01 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    can you look up your model's year electrical diagram and post a link? Can figure it out from there.
  6. Aug 26, 2019 at 11:01 AM
    Colchicine
    I hadn't considered that! It would indeed be the simplest thing, since all I'd have to do is move the trigger wire to the low beams.
    I currently have it wired so the light bar can operate independent of the headlights. But really, I've put in too much time on this for it to be worth doing much more.
  7. Aug 26, 2019 at 12:30 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    That's kind of a weird requirement. You'd think that, if anything, low beams would be the worst possible time to have the light bar turned on, because that's when you're likely driving around town, or trying not to blind on-coming cars.
    Of course I realize we're talking about government bureaucracy, and when has that ever made sense, lol...
  8. Aug 26, 2019 at 12:34 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    If you use the normally closed contact of the relay, and hook the relay coil to the high beam lights (instead of a switch), the lights will switch off whenever you turn on the highbeams and be on the rest of the time.
  9. Aug 26, 2019 at 12:43 PM
    Colchicine
    I do have a switch on the dash just for that. The light bar will be off 99% of the time.
    I don't want that, and it would likely be illegal since the light is not DOT approved.
  10. Aug 26, 2019 at 12:48 PM
    0xDEADBEEF
    Oooh. I feel like I misread your post. The most straightforward way is two relays in series - one driven by your switch through the NO contacts, and then the second driven by the high beam wire through the NC contacts.
    You're right that a DPDT isn't going to do what you want.
  11. Aug 26, 2019 at 12:50 PM
    Colchicine
    That's... disappointing. Since it come from an electrical engineer, although he hasn't been in the field for 20 years...
  12. Aug 26, 2019 at 12:52 PM
    0xDEADBEEF
    He might have also misunderstood :) That said, relays are surprisingly elusive sometimes.
  13. Aug 26, 2019 at 1:06 PM
    jbrandt
    Justin
    I figured you did, I just mean as far as requiring the lights to only have the ability to be switched on with low beams. Just seems backwards...
  14. Aug 26, 2019 at 1:08 PM
    Colchicine
    It's not ideal, but since I'm nearly a month overdue on my inspection I think I'll go the easy route for now and do the dual relays in series like
    0xDEADBEEF described.
