Wiring lights to your bed light?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by truckstick101, Apr 3, 2019.
  1. Apr 3, 2019 at 9:41 AM
    truckstick101
    truckstick101 [OP] Master of the lean
    2018 Tacoma TRD Sport 4x2 Cement
    Has anyone wired flood lights on the same switch as your bed light? Wondering if that is easier or if I should just do a standalone setup?
    Any help would be greatly appreciated! :cheers:
  2. Apr 3, 2019 at 2:29 PM
    s.e.charles
    s.e.charles Well-Known Member
    personal opinion: easiy or not, I would want the option of either/or not both all the time.
  3. Apr 3, 2019 at 2:32 PM
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    You probably could do it, but would need to wire in a relay for the power directly from the battery. The switch would only trigger the relay. Otherwise, you would have too much current running through the switch and factory wiring to power a flood light.
    buntcake likes this.
  4. Apr 3, 2019 at 3:50 PM
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    This would be the best/easiest way to do it. Just gotta find the wire that brings the heat to the bed light and use that for the trigger.
  5. Apr 3, 2019 at 4:15 PM
    TacoTruck808
    truckstick101[OP] likes this.
  6. Apr 3, 2019 at 7:31 PM
    sandtaco2016
    sandtaco2016 Member
    2016 Quicksand TRD
    Lift, Grille, Light bars, wheels, tires
    If you don’t have bed lights, you have to do some extra work and add some factory parts.
