Wiring my truck to run blacked out (no lights)
Discussion in 'Technical Chat' started by Sponge, Jan 19, 2022.
  1. Jan 19, 2022 at 1:42 PM
    Sponge
    Sponge [OP] New Member
    Has anyone wired all lights (instrument panel, front/rear, etc.) inside cab to one main on/off switch? I run classes where we sometimes drive using night vision and any light inside/outside make it very difficult. Any ideas? Thank you much...
    cryptolime and Gunshot-6A like this.
  2. Jan 19, 2022 at 5:37 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Depending on what year your truck is that could prove to be quite difficult, you couldn't just turn the dimmer all the way down, turn the dome light to off, and turn the radio screen off?
    Gunshot-6A likes this.
  3. Jan 19, 2022 at 5:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    Brake lights would take the most effort, but suspect a bypass switch tied to the pedal switch would do it.
  4. Jan 19, 2022 at 5:44 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Pull fuses........
    6 gearT444E and Grossomotto like this.
  5. Jan 19, 2022 at 6:05 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    You can identify all the marker lights, brake lights and install a switch or relay to open those circuits. You can likely identify the power circuit to the dash lights as well. I am familiar with blackout driving and understand how sensitive your eyes can get night driving.
  6. Jan 19, 2022 at 6:28 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Get the EWD for your Truck should be simple .A fused relay to interrupt all the power sources for all the light circuits just a matter to sit down and figure things out
    Having one switch makes it simple to restore all the functions when needed .
    Electrical Wiring Diagrams
    6 gearT444E likes this.
  7. Jan 21, 2022 at 9:28 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    The OP joined TW on Wednesday, posted 1 time and hasn’t been back to check. I find most posts like this to be 1 time posters or spammers. And its a kind of bizarre post. I hope I’m wrong.
    Should he ever return I’d be most curious to know what kind of “class” uses Tacomas at night in complete dark mode using night vision optics. Other than military or law enforcement (and he ain’t either and they wouldn’t be asking us) the only purpose for this total dark mode is used by illegal poachers night hunting.
    JGO, Mmaira2018, Sig45 and 4 others like this.
  8. Jan 21, 2022 at 1:57 PM
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    It is weird this is his first and only post but Ive taken a few classes for driving with night vision, usually they have a car equipped for it. (not a military or LE class)
    Ive looked into doing this for my truck just because it would be a dumb neat trick. Same reason I spent a few thousand on night vision that ive only used 3 times.
  9. Jan 21, 2022 at 2:09 PM
    Sprig
    Ken
    Why oh why would anyone want to drive at night in total dark mode using night vision optics. You can’t do it on public roads and it would be dangerous and dumb as hell to do off road. I understand military and law enforcement but even for LEO it would be extremely, extremely rare. Poaching is the only reason I can think of. I certainly wouldn’t want to be anywhere near some dude driving dark.
    Sig45 likes this.
  10. Jan 21, 2022 at 2:10 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    You can hardwire kill switches for everything but that's doing it on "hard mode".
    Easiest way is mentioned above. Use the stalk to kill all external lights, then dim the dash lights. Take a thick sheet of cardstock and tape it over the radio screen like a flap so you can lift it and change settings.
    Tailights will still light up on brake press. That is useful even under nods, just dont want them to be that bright. Take painters tape and cover the entire tail light with a layer. Then cover the entire tail light minus just a small area a few additional times until sufficiently dark. Essentially makes your taillights "cateyes" that are functional but wont autogate your stuff.
  11. Jan 21, 2022 at 2:18 PM
    Gunshot-6A
    Conner
    Everett, WA
    One post and out? That is a little odd. The rest isn't an entirely uncommon question, a different person asked about this a few weeks ago on here and I've been asked the same by several folks in person as well from multiple professional backgrounds.
    You can take NVG / Vehicle NVG classes as non-LEO / Non-Mil. Additionally, it takes basically zero effort/creds to become an instructor so its possible the guy is running a small training operation and happens to have a tacoma as a training vehicle. Pigs and coyotes are commonly hunted at night as well, and very skittish around visible light sources. All a just dandy reasons to ask.
    Yes, there's a safety element to be aware of, but that can be overcome with an ounce of common sense. Usually the areas where hunting is good is where other people aren't as the default anyways. If for training use, its likely on a flat range where other traffic is likely non-existent.
    huntercole and wi_taco like this.
  12. Jan 21, 2022 at 2:20 PM
    LiquidArrogance
    LiquidArrogance Well-Known Member
    Streets of Bakersfield
    2021 SSM Sport 4x4
    Don't forget drug running and human trafficking.
  13. Jan 21, 2022 at 2:22 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    What kind of Special Forces shit is this? Do you Halo into your driveway before driving your truck away?
    Mmaira2018 likes this.
  14. Jan 21, 2022 at 2:23 PM
    LiquidArrogance
    2021 SSM Sport 4x4
    You seem to be missing how badass this dude is.. clearly he plays CoD not Halo! /s
  15. Jan 21, 2022 at 2:24 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    also useful for evading law enforcement. not that i recommend doing that.
  16. Jan 21, 2022 at 2:24 PM
    Gunshot-6A
    Conner
    Everett, WA
    Drug running > regular running :D
  17. Jan 21, 2022 at 2:24 PM
    LiquidArrogance
    2021 SSM Sport 4x4
  18. Jan 21, 2022 at 2:24 PM
    Bivouac
    I can`t speak for others in my case it was just big Boy Toys !
    Sometimes retired operators enjoy doing strange things just for fun.
    When you live where you can drive for miles and only need to cross a public road now and then.
    wi_taco and Gunshot-6A like this.
  19. Jan 21, 2022 at 2:25 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  20. Jan 21, 2022 at 2:26 PM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    Likely English as his Second Language, the textbook grammar is a dead giveaway.
