Wiring mystery: What were they doing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by One-up, Aug 7, 2020.
  1. Aug 7, 2020 at 1:15 PM
    One-up
    One-up [OP] Member
    2017 DC LB TRD SPORT 2WD
    PRO Grille, Clazzio Seat Covers, Cab Chrome Blackout, Too Much to List
    First, Hello! This is my first TW post! I'm looking for a little help...
    I have a 2017 double cab long bed TRD Sport - with tech and convenience packages - that I believe was some sort of fleet vehicle before I bought it. When I went behind the driver's kick panel to install a trailer brake controller (the braided bundle of wires in the pics), I found that several wires had been tapped, but whatever was connected is gone. I wonder if anyone would be able to tell me what those wires are (so I can tell if they may be useful for something I'd like to do) and maybe pose a guess as to what the previous owner was doing? I'd appreciate the help.
    The pictures are a bit busy, so here's some clarification:
    The blue, black and white wires (blue and yellow taps) are off the left-most harness in that row.
    The yellow wire (red tap) is on the white connector.
    The blue and teal? wires (black taps) are on the right-most harness in that row.
    Thanks in advance...
  2. Aug 7, 2020 at 1:32 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Well, at least they used taps that take terminals instead of cutting and splicing wires.
    One-up[OP], CrippledHo and 4x4_Taco like this.
  3. Aug 7, 2020 at 1:34 PM
    4x4_Taco
    4x4_Taco Well-Known Member
    FL
    Silver SR5 4x4
    Possible that the previous owner had lighting accessories installed and took them out before it was traded in?
  4. Aug 7, 2020 at 2:17 PM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    If it was a fleet vehicle it might have been for a GPS or tracking system. My daily-driver is a company owned F550 which had a tracker installed on it a couple of months after I got the truck. Mine is installed in a similar fashion.
    Could also have been for an aftermarket alarm system.
    whatstcp likes this.
  5. Aug 7, 2020 at 2:27 PM
    One-up
    One-up [OP] Member
    Yeah, my first thought was GPS monitoring or that it could have been an escort truck for oversized loads with extra lighting and such.
    I wish I knew what those wires are for. That might help solve the mystery...
  6. Aug 7, 2020 at 2:28 PM
    One-up
    One-up [OP] Member
    No kidding.
  7. Aug 7, 2020 at 2:31 PM
    5nahalf
    Erik
    Minnesota
    I think that harness leads into the door, so that makes me think its a aftermarket keyless entry/alarm system.
    whatstcp and Gunshot-6A like this.
  8. Aug 7, 2020 at 2:34 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Welcome to The Forum! :thumbsup:
    RobP62 and jmauvais like this.
  9. Aug 7, 2020 at 2:50 PM
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    The port option work is that janky. Mine has the garbage scotch locks in a few places. I'll get around to doing it right one day.
  10. Aug 7, 2020 at 3:04 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Looks like it could be something to trigger/respond to electronic door locks based on the OEM tailgate installation instructions (page 14, figures 6-1 and 6-2).
    I haven't personally seen the schematics for that plug posted here but I'd be willing to wager that it's already in several threads, perhaps search on driver kick panel harness or plug or connector if you're truly interested in what each wire is doing.
    I would expect speed, gear, etc harnesses up in the dash but I wouldn't think there's any reason to send those signals to the doors or rear of the vehicle so I wouldn't expect them in the kick panels.
    If I had to totally guess, blue/black wires with blue taps would be lock/unlock pulses, the yellow tap is for +12v and the bottom red tap is IGN switched?
    ^^ regarding the wires, see post from caribe makaira below, my guess was clearly wrong :) Funny part is, I even mention doors open/closed below but didn't think that you'd likely want to know if the door is open or not for anything which is monitoring or controlling the door locks.
    if you have a multi-meter, since the taps are already there, you can see for yourself, test all 4 with vehicle off and doors closed, test with doors opened, test pressing lock, test pressing unlock, test turning acc on.
  11. Aug 7, 2020 at 4:47 PM
    caribe makaira
    Caribbean, Puerto Rico
    Connector IE1 - Yellow wire is Driver's Door close/open switch.
    Bleep100, One-up[OP] and daveeasa like this.
  12. Aug 7, 2020 at 4:51 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    T-Taps are clean and simple. I have to agree....at least it's not a hack job.
    Pull them off and cover the insulation slice with a bit of electrical tape. Call it a day
    RobP62 likes this.
  13. Aug 7, 2020 at 5:00 PM
    caribe makaira
  14. Aug 7, 2020 at 9:00 PM
    One-up
    One-up [OP] Member
    Thanks for the information!
    I guess fleet vehicles might get configured to have the same key as others in the fleet? That would explain the door locks, but the power window is odd to me. Eh, well... at least I know what they are. Thanks again.
    RobP62 likes this.
  15. Aug 7, 2020 at 9:38 PM
    Schlucki
    Schlucki Well-Known Member
    Rich
    North Dallas, TX
    2020 DCLB TRD OR 4X4 Cement Taco
    A growing list of stuff
    Definitely alarm installer T-taps. Most likely an alarm that was installed previously and then pulled at the dealership before selling as a used truck. Dealers want no part of reselling a vehicle with an aftermarket alarm that will give them headaches....
    Although much better than cut and butt connections, a T-tap often severs some strands of the wire. I wouldn't lose sleep over it at all though.
    soundman98 and RobP62 like this.
  16. Aug 7, 2020 at 9:57 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I wouldn’t pull the t-taps off unless I was going to repair the wire replacing the section the t-tap was. They cut into the sides of the wire and removing them will remove the support the tap gives, leaving you with a weakened copper wire notched on the sides. Removing them could also cause more damage cutting into the copper more.
    A butt splice or even a twist lock connector is superior to a t-tap. Having said that I have used t-taps they just have to be secured and not messed with.
  17. Aug 12, 2020 at 2:23 PM
    One-up
    One-up [OP] Member
    Thanks for the info.
    I'll probably just leave them alone. I'm about to add bed lights, rear lights, anytime front/backup cam, and maybe a lower grille light bar. I don't think any of these taps will be useful for any of that. I'll just go to the fuse box for switch signals (to a relay) and the battery for power as needed.
  18. Mar 15, 2025 at 7:11 AM
    Ttfran1t
    Ttfran1t Well-Known Member
    Tim
    Mentor, Ohio
    2013 Grey Tacoma Sport Extended cab
    nothing as of yet
    Thanks for this info. Trying to remove an aftermarket alarm that went bad on me during test drive. 5 years later, decided to remove it. The dealer refused to do it when purchased. And as I was moving truck noticed window wouldn't work and no locks. So I thank the poster of the pictures, we are in a rain storm with trash bag taped to window.
  19. Mar 15, 2025 at 8:51 AM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    I had the port added led/drl fogs on my truck with these taps. I replaced the fogs and harness yrs ago I did seal the wire the taps were on but yrs later same electrical issues with something in the door not working (window/door or side mirror) can’t remember which but when I finally figured it out I had soldered a wire loop to the severed wire tap (no slack to solder ends together) then I used a label maker- reads Toyota wire tap fail
  20. Mar 15, 2025 at 8:57 AM
    baldbeardedtaco
    FL
    I could repin it and I’d have only 1 connection instead of 2 but i needed it fixed right away and now it’s not high on the list
    daveeasa likes this.
