wiring opinions
Discussion in 'Performance and Tuning' started by colby8100, May 10, 2013.
  1. May 10, 2013 at 9:45 AM
    colby8100
    colby8100 [OP] Well-Known Member
    Colby
    South carolin
    01 Tacoma 1jz lowered
    Lowered,leather interior,system,1jz swap,rims,painted bumpers mirrors ect
    Ok I been working on a really hard hit honda and I got it ready for paint. So I decided to start fixing broken wires and they sent a kit of butt connector looking things that are activated by heat. When you heat it up the edges draw up and it has a little ring of solder in the center that melts into the wires. Its a lot faster than soldering then heat shrinking. I was wondering if anyone has any negative feedback on them. I'm about to redo my engine harness for my new ecu and mods and I'm thinking about using these.
  2. May 10, 2013 at 9:46 AM
    Large
    Large Red
    Use crimp-able butt connectors, electrical tape & heat shrink over it for a good connection. Solder will fail eventually.
  3. May 10, 2013 at 9:52 AM
    colby8100
    Colby
    South carolin
    That's normally what I do is crimp them then solder it the heat shrink then tape loom then tape again but these were really neat
  4. May 10, 2013 at 1:06 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    Pictures/brand?
  5. May 10, 2013 at 1:15 PM
    Aw9d
    Aw9d That one guy
    Az
    Solder fails only if it was soldered bad or there is a lot of stress on the solder joint. Which in a Honda will not happen. I've built custom harnesses for race Honda's and never seen one joint fail.
    I've never had any of my solder fail on me. I've been installing stereo's for around 13+ years and doing electrical work for as long as I can remember. I don't use crimps unless there is no other choice (Which is rare).
    Personally, solder + heat shrink is the way to go. It will give you the best connection possible. Yes it takes longer but its the best way.
  6. May 10, 2013 at 1:18 PM
    colby8100
    Colby
    South carolin
    I don't have a brand its just what the shop stocks
  7. May 10, 2013 at 1:21 PM
    colby8100
    Colby
    South carolin
  8. May 10, 2013 at 1:22 PM
    Aw9d
    Aw9d That one guy
    Az
  9. May 10, 2013 at 1:23 PM
    colby8100
    Colby
    South carolin
    The clear heat shrinks the blue melts into a sealer? And solder melts and bonds
  10. May 10, 2013 at 1:23 PM
    colby8100
    Colby
    South carolin
    The ones I have don't crimp
  11. May 10, 2013 at 1:24 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Not if done properly.
  12. May 10, 2013 at 1:36 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I would not use that type.
    Solder is to ensure a good electrical connection.
    Prior to soldering, you need a good mechanical connection, whether it be a western union or a crimp connection.
    The solder prevents corrosion from degrading the connection over time, and helps prevent vibration from degrading the mechanical connection.
    Solder joints that fail are generally caused by one of several issues:
    1) Connection overheated and the solder crystallized (not common).
    2) Conductors overheated and solder wicked along the stranded conductors beyond the stabilized connection area... the stranded wire has become "solid" and is prone to break from vibration if not supported (very common).
    3) Cold joint - Joint not properly heated, solder applied to the iron tip and merely flowed around the conductors encapsulating them, but not creating a bond. Apply heat to the joint, and apply the solder to a part of the joint away from or on the opposite side of the tip. The solder should melt and be drawn into the joint. If it balls up on the surface, it will not create a good joint (extremely common).
    4) Improper cleaning - Old solder, flux is no longer good or even present, conductors oxidized and not cleaned. IF you get it to "stick", it will be a cold joint.
    5) Improper flux - Acid flux should NEVER be used for electrical work. Even if rinsed off, the flux has wicked back into the stranded conductors and the copper will corrode and fail within months (common among the inexperience with a "plumber friend").
  13. May 10, 2013 at 1:43 PM
    colby8100
    Colby
    South carolin
    I'm assuming the blue is a glue I didn't trust them so I lapped two pieces of wire slid it one melted it and pulled hard and it took a lot to break the wire but they are new to me
  14. May 10, 2013 at 2:21 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    If you had a solid western union prior to slipping the connector over, then you're in better shape than most people who use these.
    Personally, I use the western union, solder, and an adhesive-lined 3M shrink tubing. It costs twice as much as regular shrink tubing, but the entire inside is lined and the result is completely weatherproof.
    All of my wiring on the motorcycles or under the hood uses that. Anything in the cab uses regular heat shrink.
  15. May 10, 2013 at 2:30 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    that is a first--SOLDER connections fail--
    Not if done correctly--I am NOT familiar with the type listed here.
    Solder is the best form of connection.
    EXAMPLE--copper water pipes in your house.
    Former MARINE Tech--we soldered EVERYTHING.
    Keeps out corrosion-best electrical BOND.
  16. May 10, 2013 at 3:39 PM
    deez
    deez Well-Known Member
    Darren
    The I.E. - SoCal
    2002 V6 SR5 TRD 4WD
    Too many to list
    They're called solder splices. The blue rings on each end melt to seal the ends up.
  17. May 10, 2013 at 4:39 PM
    deez
    Darren
    The I.E. - SoCal
    2002 V6 SR5 TRD 4WD
    Too many to list
    Speaking from professional experience (as a wiring loom designer and builder), Rich91710 pretty much nailed it.
    Solder shouldn't be used as a primary means of splicing wires together. If done correctly, a mechanical crimp (with SCL or marine-grade heatshrink over it) will suffice. But the key here is a proper crimp. Too tight of a crimp and you stress the wire strands, which can lead to breakage from vibration. I think we all know what a loose crimp can lead to.
    Don't cut corners with wiring. Do it right the first time. Trust me, the time invested now will save you from potential headaches and issues in the future.
  18. May 10, 2013 at 5:10 PM
    colby8100
    Colby
    South carolin
    I do western mine I'm certified in automotive wiring and air bag wiring I was wondering yous guys (in a yankee voice) opinion I usually do it like deez said but I was wondering if this was a new (same quality) alternative my vote is no
  19. May 10, 2013 at 5:11 PM
    colby8100
    Colby
    South carolin
    Ps you can't use mechanical clam on airbags could affect resistance
  20. May 10, 2013 at 5:40 PM
    deez
    Darren
    The I.E. - SoCal
    2002 V6 SR5 TRD 4WD
    Too many to list
    Good to know. No air bags in my field to deal with - primarily EFI and data acquisition/management for racing.
    The only time we use those solder splices is to splice a wire onto a shield (shielded cable).
