Wiring OTTRAW switch to operate A-TRAC
Discussion in 'Technical Chat' started by Black15TRD, Mar 27, 2015.
  1. Mar 27, 2015 at 12:25 PM
    Black15TRD
    Black15TRD [OP] Well-Known Member
    Wichita Falls
    2015 TRD Off-road
    Toytec Boss coilovers (set at 3" lift), LR UCAs, 2" AALs, Boss Shocks, Retrofit headlights, LED fog lights, and more...
    So, I'm in the process of swapping the center dash switches in my '15 Tacoma to all OTTRAW switches to match the 5 switches that I installed in the front lower center console area. I've got everything done, but I can't find a wiring diagram for the factory A-TRAC switch anywhere.
    I've got the ignition power, dimmer light power and grounds run to the SPST OTTRAW switch, but I can't figure out what wire needs to go to the accessory spot on the switch.
    I think the middle 2 wires on the factory A-TRAC plug are for the dash lights and one of the wires is for ignition power. Do I just plug the 4th wire into the accessory spot on the OTTRAW switch??
    Any help would be greatly appreciated.
  2. Mar 27, 2015 at 11:59 PM
    Black15TRD
    Wichita Falls
    2015 TRD Off-road
    Awesome!!! That's exactly what I needed. Thanks!!
  3. Jan 18, 2016 at 6:00 PM
    Phoosa
    Phoosa I never saw nothing.
    Truck
    You have the wiring diagram for the A-Trac switch?
  4. Jan 20, 2016 at 7:36 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    its just a momentary switch, SPST
  5. Jan 20, 2016 at 7:37 PM
    Phoosa
    Truck
    Trying to figure out what wire is what. Plan is to extend wiring to left of steering wheel.
  6. Jan 20, 2016 at 7:46 PM
    PSU Taco85
    optional
    On my 2010 red/black is the hot coming from the skid control ECU and white/black is the ground. The rest if there are any, are for illumination
