Wiring oznium LED lights...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Healyj7, May 14, 2016.
  1. May 14, 2016 at 2:55 PM
    Healyj7
    Healyj7 [OP] 2010TRD Cape Cod
    Cape cod MA
    2010 Tacoma 4x4 crew cab...
    Led third brake light All bulbs changed to LED Blue... Bed cover Extra tie downs in bed Borla 3' aftermarket excuast Blacked out front grill Smoked front lights White turn/running lights Bed security Mod 2 inch front lift and level with bilstein front and rear shocks... 1 Inch wheel spacers BF Goodrich AT tires 270/75/17
    I purchased
    5 x Prewired Superflux 4 Chip LEDs - Blue
    1 x Round Rocker Switch - Blue LED
    I would like to place the LEDs in the cup holders center console tray and in center console compartment with the rocker switch above the aftermarket radio I have my question is.... The rocker switch came with three wires 1 black and 2 red the LEDs came with 1 red and 1 black. After putting the Leda where I want them what would be my wire setup? I also purchased a add a fuse to hook everything up to the power from the fuse box under that handy pull down change/candy holder. How do I connect all the Leds to run off one switch, how do I group them together to attach to the one wire comeing from the switch and then what wire goes to the add a fuse? Is the black wires the ground? This is my first electrical Mod as you can read I have no experience any help would be great!!!
  2. May 14, 2016 at 3:13 PM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
