Wiring problem, aftermarket lights wired to stock fogs
Discussion in 'Lighting' started by mxxdude, Dec 18, 2012.
  1. Dec 18, 2012 at 8:36 PM
    mxxdude
    mxxdude [OP] Well-Known Member
    Brandon
    Tucson AZ
    06 4x4 TRD
    So i bought my truck as is, the offroad lights didn't work at all. its a trd sport that came with fogs, but has an aftermarket bunper, however the wiring is wired to the offroad lights. Nothing happened at all when I went to turn them on, I replaced the relay with a good one. The interior switch comes on and the relay clicks when I press it , also the bulbs are good In the lights,
    What could be be problem? Thanks
  2. Dec 18, 2012 at 8:40 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Fuse? The switch and relay are driven from a separate fuse from the lights themselves.
    Also, the factory fog light wiring shuts them down when the high beams are on unless the "anytime" mod was done.
  3. Dec 18, 2012 at 8:40 PM
    mxxdude
    Brandon
    Tucson AZ
    06 4x4 TRD
    Also the fuse in the engine compartment is good, and my low beams are on when I Try to turn them on
  4. Dec 19, 2012 at 11:32 AM
    mxxdude
    Brandon
    Tucson AZ
    06 4x4 TRD
    Yikes any ideas at least? Wiring to the lights or ground? Or what
  5. Dec 19, 2012 at 11:38 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Yes.
    Do they have an easy conector to the lights? You could check to see if power is getting to them or if it's a ground problem.
  6. Dec 19, 2012 at 3:15 PM
    mxxdude
    Brandon
    Tucson AZ
    06 4x4 TRD
    Thanks everyone! Turna out they just weren't getting enough power!
