Wiring problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hopper1972, Apr 7, 2020.
  1. Apr 7, 2020 at 5:38 PM
    Hopper1972
    Hopper1972 [OP] Member
    2011 Toyota Tacoma TRD
    Upgraded stock radio
    I have a 2011 Tacoma and I upgraded my stock radio with an aftermarket unit. I started removing the stock unit and I noticed a cluster of wires spliced in the trucks OE harness very close to the connectors.i removed all the extra wires and connected everything back to stock as best I could. New radio is installed but I hear a cracking sound when I turn it up slightly. I've been told it's a ground problem but how do I know which wire to look for in the harness? There are several black wires in the 3 different connectors. Can I get a new OE connectors with leads so I have room to get more wire to splice in?
  2. Apr 7, 2020 at 9:15 PM
    LAMCKMA007
    LAMCKMA007 Well-Known Member
    San Diego county
    2006 DCLB 2WD
    Toyota sells "theft kits" for their vehicles however I've never needed one for a second gen. Theft kits come with any necessary brackets, screws, and wiring harnesses with about 8" of wire coming out of the plugs.
  3. Apr 8, 2020 at 1:44 AM
    Hopper1972
    Thanks! I might just go that route. Just so I know that connections would be better.
  4. Apr 8, 2020 at 1:49 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
  5. Apr 8, 2020 at 2:07 AM
    Thuguon2.7
    Thuguon2.7 Cheeehuuu
    J
    SoCal.
    ‘15 1GRFESR5AC
    Are you using an aux chord , or Bluetooth?
  6. Apr 8, 2020 at 2:09 AM
    Hopper1972
    With the stock radio I used an aux cord. The new head unit is Bluetooth and I have the adapter box for it.
  7. Apr 8, 2020 at 2:32 AM
    Thuguon2.7
    J
    SoCal.
    ‘15 1GRFESR5AC
    Ok, so are you using BT or Aux?
    I’m asking cause an aux being bent at a certain angle while plugged makes a scratchy noise sometimes or sounds like a speakers blown..
  8. Apr 8, 2020 at 2:36 AM
    Hopper1972
    The new unit is Bluetooth.
    Thuguon2.7 likes this.
  9. Apr 8, 2020 at 4:57 AM
    Hopper1972
