Wiring question for new grille
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MrExcitment, May 5, 2020.
  1. May 5, 2020 at 7:21 PM
    MrExcitment
    MrExcitment [OP] Member
    Atlanta GA
    2019 Cement SR5
    First time poster here so be gentle.
    So recently bought a new grill for my 2019 Taco and I went with the Taco Vinyl Raptor Grille 2.0 with the led side lights. I'm fairly inexperienced in this sort of stuff but after watching the YouTube video posted on the sellers page it seems simple enough. Only after starting to install my grill I notice the video is a 2016 Tacoma and the wires into the blinker and Drl don't exactly match up with what's under my hood.
    So in short I'm just looking for some help figuring out what the wires running into the back of both of my lights are so I correctly splice them. I have tried my best to find it simply by googling but I've come up short.
    So if someone can shoot me pic with some labels for this rookie I would greatly appreciate it.
    blm4097 and Tullie D like this.
  2. May 5, 2020 at 8:10 PM
    Shellshock
    Iowa
    I’d just get an add a fuse and run it to the fuse box. I don’t like cutting up factory wiring
  3. May 5, 2020 at 8:11 PM
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    He cant. He has to tie into the signal lights
  4. May 5, 2020 at 8:12 PM
    cruxx
    Huy
    2017 TRD Sport
    Get yourself a little test light and figure it out the old fashioned way
  5. May 5, 2020 at 11:44 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Welcome to the forum from Eastern North Carolina!
    The SR and SR5 trim levels DRL are different from all of the other trim levels. Short version: the front turn signals do double duty - they also serve as DRL. I can't tell you how to accomplish what you want to do. Just be aware of the trim level differences when people start telling you how to do it.
    Good luck with it!
  6. May 6, 2020 at 3:27 AM
    MrExcitment
    Atlanta GA
    2019 Cement SR5
    Hey thanks! I didn't even think about that. Ok that makes alot more sense. Also as someone said above I'll grab my testers and check that as well. You guys are great! Knew I'd get some help here.
  7. May 6, 2020 at 5:56 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Welcome to TW. Do a search for electrical stuff and prepare for DAYS of reading. There have been as many screw-ups as there have been successes when it comes to electrical on these trucks. Simply: They don't like it!!
    G.
  8. May 6, 2020 at 6:11 AM
    Shellshock
    Iowa
    Skydvrr likes this.
  9. May 13, 2020 at 6:06 PM
    19trdoffroad
    19trdoffroad Well-Known Member
    Chava
    Wasco, CA
    19 TRD OR 4x4 MT
    Did you figure it out?
  10. May 13, 2020 at 6:20 PM
    MrExcitment
    Atlanta GA
    2019 Cement SR5
    So I got it all hooked up with a friend's help. Not sure it's completely correct but everything comes on correctly.
    The only thing that is off is when first turning the led lights on in the grill the driver side hesitates for a second. But I think this is just because we hooked it up to the raptor lights for power. So maybe the amps are not quite high enough at first. I really don't understand electrical so I cant speak to much on it.
    But my TSS sensor keeps telling me it needs to be cleaned. So gotta figure that out, already tried cleaning the plexiglass with glass cleaner doesn't seem to help.
  11. May 13, 2020 at 6:22 PM
    19trdoffroad
    Chava
    Wasco, CA
    19 TRD OR 4x4 MT
    What does your bracket for the sensor look like?
  12. May 13, 2020 at 6:24 PM
    MrExcitment
    Atlanta GA
    2019 Cement SR5
    Metal bracket that's attached to the grill. With a piece of Plexi glass in the front. Can shoot you a pic if needed.
  13. May 13, 2020 at 6:28 PM
    19trdoffroad
    Chava
    Wasco, CA
    19 TRD OR 4x4 MT
    Send the pic!
  14. May 13, 2020 at 6:35 PM
    19trdoffroad
    Chava
    Wasco, CA
    19 TRD OR 4x4 MT
  15. May 14, 2020 at 3:31 AM
    MrExcitment
    Atlanta GA
    2019 Cement SR5
    So I followed that video but it's a 2016 so the wiring isn't the same.
  16. May 14, 2020 at 10:38 AM
    19trdoffroad
    Chava
    Wasco, CA
    19 TRD OR 4x4 MT
    Just noticed you have an sr5 do you have drl?
  17. May 14, 2020 at 10:39 AM
    19trdoffroad
    Chava
    Wasco, CA
    19 TRD OR 4x4 MT
    I have 19 as well and wiring was the same
  18. May 14, 2020 at 10:39 AM
    19trdoffroad
    Chava
    Wasco, CA
    19 TRD OR 4x4 MT
    Can send you pics if you'd like
  19. May 14, 2020 at 12:51 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I installed grill lights on my sr and tried to add a circuit into the fuse box into the drl fuse but the sr and sr5 tacomas don’t have a drl fuse so I ended adding a fuse into the injectors. I did consider tapping into the power wire of my drl bulb socket but didn’t want to use an alligator clip.
  20. May 14, 2020 at 1:16 PM
    D-tronics
    D-tronics Member
    Dan
    Medford, OR
    2017 Tacoma SR5 DBC 4x4 Silver Sky Metallic
    ATX 202 wheels, MBRP turn down exhaust, Pedal Commander, Kicker speakers, Rockford Fosgate 8" sub and Rav 4 side mirrors.
    So I just installed raptor lights last weekend, I wanted to run them with the "marker" light setting. So I ran the positive wire through the fire wall and used an add a fuse in the "tail light" fuse location. So it comes on when I go one up from the DRL option and stays on with the headlights.
