wiring question.. soldering wires?
Discussion in 'Audio & Video' started by campagna, Oct 11, 2011.
  1. Oct 11, 2011 at 11:16 AM
    campagna
    campagna [OP] Member
    anyone have a picture of what its suppose to look like? i have the pioneer Pioneer AVH-P2300DVD
    im trying to do the wiring i have the adapter.. is it just doing color to color then installing or is there more to it.. plus do you have solder them
  2. Oct 11, 2011 at 11:17 AM
    enjm10
    enjm10 Well-Known Member
    Eric
    NM
    2020 White Double Cab
    5% Front strip and doors, 20% wrapped around the rest of the truck.
    Color to color u can use crimp caps to make it easier. Unless u feel like soldering n taping em
  3. Oct 11, 2011 at 11:28 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Solder and heat shrink > Crimped connections
    Don't use electrical tape as your only form of wire insulation. I made that mistake once and my deck shorted out.
  4. Oct 11, 2011 at 12:09 PM
    jasonvelocity
    jasonvelocity Well-Known Member
    Palmer Lake, CO
  5. Oct 11, 2011 at 12:14 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    if you do use electrical tape. you can use a small zip tie to hold prevent the tape from loosening over time.
    A zip tie gun is also helpful here too
    but heat shrink is the best.
    one note, let the heat pull the solder through the connection. ie heat the backside and put the solder to the opposite side of the wire and the heat will pull the solder through. you dont just want it on the outside of the connection (cold solder)
    Personally, I solder everything, but some quick connects are nice, most cheap ones suck
    Justin
  6. Oct 11, 2011 at 2:21 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I didn't look at your link, but I wanted to throw my two cents in really quick before I go back to work.
    Soldering is not flexible, it will break it you try to bend it. Basically you increase your risk for failure down the road. That being said, I'd do it, but I have special Raychem splices that heat shrink and reinforce the connections.
    I'd suggest a good butt connector, and one with some thick heatshrink. Standard heat shrink can wear away over time, risking a short.
  7. Oct 11, 2011 at 2:37 PM
    Pugga
    Massachusetts
    Soldering only gives you maybe 1" of an entire wire that can't be bent around. Wires behind a stereo shouldn't be moving a bunch anyways and if you get solder completely through both wires, it's tough to break them apart. Seems like the Raychems are just a crimp joint with heat shrink around them, no?
  8. Oct 11, 2011 at 4:36 PM
    campagna
    thanks guys! useful info!!
  9. Oct 11, 2011 at 5:15 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I've installed a few stereos using butt connectors made of heatshrink and have had no issues. Looks clean and has lasted many years. They are made by Ancor.
  10. Oct 11, 2011 at 5:21 PM
    brian
    Elizabeth City, NC
    Theres many kinds of raychems. There are solder splices that are generally made for shielded wires, and then the barrel type crimps. Either way, when you shrink them down, the barrel becomes quite solid, completely environmentally sealed, and strong enough to resist nicks that normal heat shrink would fail on.
    It may be overkill, but I like to do it the right way the first time instead of the slight risk. You never know when the swiss cheese model will line up and bam, you smoke check something. I'm always working on my stereo it seems, my decks come in and go out, wires get pinched all the time because at one point I had so much crap behind the dash.
    Also, when splicing, stagger your connections, it will make it much easier to fit all the wire back in :)
  11. Oct 11, 2011 at 8:20 PM
    enjm10
    Eric
    NM
    I have always used crimp caps n they worked fine, had installed all my stereos in my vehicles. Never once had a problem.
  12. Oct 12, 2011 at 6:23 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I also seem to be adding/modifying my stereo stuff a couple times a year. "asbestos undies on" But I've used wire nuts for 20+ years on car stereo installs and have never had one pull out, nor had a bad connection. Certainly eases adds/modifies/deletes.....
  13. Oct 12, 2011 at 9:07 AM
    campagna
    also where is the best place to put the ground wire?
  14. Oct 12, 2011 at 9:17 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Anywhere that grounds to the chassis. There should already be a ground pin in the main harness so you should use that. No reason to get fancy.
  15. Oct 12, 2011 at 9:25 AM
    campagna
    im not seeing it.. is there a picture someone can show me? everywhere is plastic.
  16. Oct 12, 2011 at 9:35 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Soldering is better than crimping but if you do crimp at least use some shrinking crimps and shrink the edges around the wire. I did that in my S10 and it held up fine just make sure you have a good crimp on the wires.
  17. Oct 12, 2011 at 9:37 AM
    enjm10
    Eric
    NM
    I had a wire harness from Crutchfield and connected my stereo harness into my harness adapter from Crutchfield n connected the ground wire through both harnesses eliminating the use of trying to find a ground. Just tap the wire into the ground of the trucks harness.
  18. Oct 12, 2011 at 9:44 AM
    campagna
    so put into the harness? i dont have jbl if that makes a difference..
    IMG_9646_dd8e377eb5c62b5cff6f4100bb974319a838188c.jpg so am i suppose to hook that into the wires behind?
  19. Oct 12, 2011 at 9:44 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i pretty much use crimps with enviromental sheilding. I mean if its good enough to use on a 24million dollar ah-64D apache that sees more stress and oil and hydralic fluid than any car i have ever driven, then it is good enough for my 30k dollar toyota
  20. Oct 12, 2011 at 9:46 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    there should be a ground wire in the wiring harness adapter that plugs into the factory harness. cut the semi ring connector u are holding in the pic of and splice/solder/glue/whatever u want to use, to connect to that wire.
