Wiring question
Discussion in 'Lighting' started by 2dmay3, Sep 11, 2016.
  1. Sep 11, 2016 at 6:18 PM
    2dmay3
    2dmay3 [OP] Well-Known Member
    doug
    Seneca mo
    2016 Tocoma SR5
    Falken Wild peaks AT/3 265/75-16 Wade Sure-Fit Floor Mats AVS window visor red Toyota logo emblem trd off-road shiftier knob 32 inch light bar in grill and ditch light pods
    Okay just got a new wiring harness for my LED light bar need a little help my rocker switch has red red black wire harness as white blue black anything will help I now black to black just not sure on the other two colors
  2. Sep 11, 2016 at 7:17 PM
    caribe makaira
    Caribbean, Puerto Rico
  3. Sep 11, 2016 at 7:18 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  4. Sep 11, 2016 at 7:20 PM
    caribe makaira
  5. Sep 11, 2016 at 7:33 PM
    2dmay3
    doug
    Seneca mo
    2016 Tocoma SR5
    thanks for help me out
  6. Sep 11, 2016 at 7:37 PM
    Launch21v
    Launch21v Well-Known Member
    Fontana, CA
    16 TRD sport dclb 4x4 tech pack w/jbl white
    Can we see some more pictures of your feet? :yes:
    rollin904 and Siblue like this.
  7. Sep 11, 2016 at 7:48 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Lol Idk what kind of magic is going on there
  8. Sep 11, 2016 at 7:51 PM
    2dmay3
    doug
    Seneca mo
    2016 Tocoma SR5
    that's why i asked for help the instructions suck ass the paper they give is not much better
  9. Sep 11, 2016 at 7:54 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    You can always count on @caribe makaira for marked up pics and diagrams. I didn't even look to close at the one I posted, though there is this one I found too.
  10. Sep 11, 2016 at 7:54 PM
    caribe makaira
    Do this so it doesn't stay lit always...
  11. Oct 8, 2016 at 12:19 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'm going to piggyback off of this thread so anyone searching can hopefully find a few answers they're looking for all at once and not have any questions left about wiring up this kind of switch when they're working on this kind of project.
    I have some LED fog lights that I'm installing and I have a base model regular cab prerunner so I don't have any wiring already in my truck for fog lights. I ordered this wiring harness as it was suggested to me to be plug and play. Here's the harness:
    https://www.amazon.com/gp/product/B00QYIZ890/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
    I now would have made my own wiring harness after watching these diy videos:
    https://www.youtube.com/watch?v=b8GY69Ci7l4
    However I have my wiring harness that I already paid for so I might as well try to make it work right?
    As it is I have my switch connected like the OP I believe and what is shown in diagram in post #9:
    So the only thing that I am unsure of is where to connect the hot wire (red) that comes off of the switch connector:
    As suggested in post #10 I should put an add a circuit coming from the fuse panel in the cabin, which is what both of these videos suggested as well. Should I cut off the end of that red wire coming off of the connector and solder an add a circuit to it and plug it into a fuse terminal in the cabin fuse panel? If so, is there a good fuse terminal to use that has power even when the ignition is switched off? Thank you.
  12. Oct 9, 2016 at 10:10 PM
    caribe makaira
    If you want the added lamps to be one anytime then no reason to mod the harness, it's meant to have juice at all times.
  13. Oct 9, 2016 at 10:31 PM
    kolelt
    kolelt Well-Known Member
    The red + wire should trigger the relay. From relay to your light or whatever you running. In other words. Your taking in a small load, sending it to your relay. Which then the relay sends it to your light which needs juice. Make sure you have a relay installed. They are pretty simple. each relay is labeled so you can google for pin outs. I recommend 40amp relay.
  14. Oct 10, 2016 at 12:23 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    :thumbsup: Thank you. I should have been more clear the harness has a relay for the lights, I was only concerned about the wire that is powering the switch in the cabin.
  15. Oct 11, 2016 at 2:33 PM
    kolelt
    Right. There should be a 12v source going to the switch. Then the switch once flipped sends power to relay. Thus relay sending power to light ( 40 Amps)
