Wiring Questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SequoiaBansheeBoogers, Jan 7, 2025.
  1. Jan 7, 2025 at 1:28 PM
    SequoiaBansheeBoogers [OP] New Member
    Hello all,
    I am looking to install an Eco-Flow Alternator Charger ( 800W ) as well as an Eco-Flow Delta 2 Max in my 2022 Tacoma TRD Sport. I already have my mind ( mostly set ) on where I'll be securing the Delta 2 Max, however I need sone guidance on installing the Alternator Charger.
    Do any of you know the easiest way to do this safely with minimal material removal to factory components?
    The Alternator Charger is supposed to hook up directly to the Truck's Battery and then be routed through to the cabin.
    Also, do any of you guys know how to easily/safely route things from the cabin to the bed with minimal material removal to factory components?
    Pictures or videos would be greatly appreciated, I am very new to this.
    Thank you in advance!
  2. Jan 7, 2025 at 2:20 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Be very careful when adding after market electrical components!
    many posts here where whatever they were doing resulted in a major sh*t show!
  3. Jan 7, 2025 at 2:26 PM
    I believe you, however I am curious... would you say this is due to ignorance /carelessness on the installer's behalf or is the Tacoma prone to such issues regardless?
    Have you seen alot of issues arise when people install alternator chargers like I am, or just in general with electrical components?
    Thank you for the insight.
  4. Jan 7, 2025 at 2:44 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I still dont know what's going on?
    You want to make it less oem reliable???
  5. Jan 7, 2025 at 4:00 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    When you add after market parts you are increasing your chances.
    kahanabob likes this.
  6. Jan 7, 2025 at 4:29 PM
    Tocamo, I want to make it more " bugout " capable as well capable of supporting 4+ dash cams. Having a solar capable power supply that can power just about anything I can fit in the truck seems to fit that bill.
