Wiring rear bumper lights
Discussion in 'Lighting' started by UberFlaco, May 14, 2020.
  1. May 14, 2020 at 6:25 AM
    UberFlaco
    UberFlaco [OP] Active Member
    2020 Cement Gray TRD Off Road
    What’s up everyone? I should be getting my new rear bumper in about a month and am wanting to install the lights on it myself. I’d like to wire them to a switch I stead of the reverse lights. Is this something I can DIY or should I take it to a professional? I’ve been searching posts and am seeing a lot of diagrams that I can’t make heads or tails of.
  2. May 14, 2020 at 6:57 AM
    Tacospike
    Quarantine A-TX
    1 Owner 16 Attitude BLK TRD Spiked Sport
    Murderface Spike Edition
    You should be fine DIY.
    They wire the same as any ditch light and any other mounted led light bar. You might need to cut and splice extensions due to the length of where they are mounted to the front engine bay to get power from the battery, and run the switch into the cab. I don't know all of the lights out there and how long the wires or for every brand so something to look in to.
