Wiring Rough Country Light Pods with DRL to turn on with DRL lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zumozuzu7, May 24, 2021.
  1. May 10, 2022 at 7:07 PM
    #41
    Tacoblaster01
    Tacoblaster01 Member
    01 tacoma
  2. May 10, 2022 at 7:09 PM
    #42
    Tacoblaster01
    01 tacoma
    The original setup doesn't have a relay setup, so according to diagram on switch I'd need 2 relays. If I could get some help on what I would need to accomplish this setup that would be great. BTW, this is my first post and very intrigued on how much help is in this forum. Thanks again
  3. May 10, 2022 at 7:17 PM
    #43
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    It’s doable and you asked nicely so we can start a DM. I’ve found it takes me a looooooiioong time and gets in the way of other stuff as a result. But I could maybe re-think things and do something functional but less intense and maybe get it done quicker.
    can you document the 3 colors and their signals? Red is power in? Blue is backlight and white is full power?
  4. May 10, 2022 at 7:47 PM
    #44
    Tacoblaster01
    01 tacoma
    So wires for the harness that feed the original toggle switch are,
    Red- positive
    Black- ground
    Blue- ditch light
  5. May 10, 2022 at 8:29 PM
    #45
    daveeasa
    David
    PNW
    Ok, that’s everything we would need outside of switch illumination which I can do with a cargo T.
    Ill see if I can carve time for a simple solution.
    Tacoblaster01 likes this.
  6. May 15, 2022 at 4:48 PM
    #46
    Tacoblaster01
    01 tacoma
    Whats up bud, wondering if you had any luck making one up? @daveeasa
  7. May 15, 2022 at 4:51 PM
    #47
    daveeasa
    David
    PNW
    Not yet. It’s in the back of my head if I get a moment. Hauling horses today/tonight. If you really want something fast then go grab two relays and I can advise on what wires to connect and you can diy.
    Tacoblaster01[QUOTED] likes this.
  8. May 16, 2022 at 7:26 AM
    #48
    Tacoblaster01
    01 tacoma
    That would be great. I can do the work, just suck at figuringout what wires ho where. Should I get 2- 30amp 4 pin replays to start?
  9. May 16, 2022 at 8:45 AM
    #49
    daveeasa
    David
    PNW
    That or hold tight and wait till I get to it.
    You’ll also need a switch illumination T harness, most likely from kmorgan3’s stash depending on where the switch goes.
    the connections you’ll make are
    1. 85 on both relays to ground on the RC harness.
    2. 30 on both relays and power in to the switch to power on the RC harness
    3. 87 on one relay to the light bar on the RC harness
    4. 87 on the other relay to the backlight or secondary output on the RC harness
    5. Switch illumination + and PWM - to the switch inputs for illumination and ground.
    which leaves only two connections from the switch, output from the top button to 86 on one relay and the other output to 86 on the other relay. Save this for last so you can plug it in and test before making the final decision. Or refer to the color charts on the switch and what you’ve identified.
    Total of 11 connections I believe with two being 3 wires together.
  10. May 19, 2022 at 8:47 AM
    #50
    Tacoblaster01
    01 tacoma
    Thank you for the information @daveeasa. I'm really not good with wiring stuff up. Lol I'll wait a bit to see if you end up making one up or got a easy way of doing it. I can attempt it if it comes down to it. Thanks again
  11. May 19, 2022 at 8:52 AM
    #51
    daveeasa
    David
    PNW
    I’m slowly clawing out of the hole I’m in. This and one other custom request are on my list of stuff I would enjoy doing when time permits. I’ll keep it active for now. I’d actually like to offer a formal product to do this since many of these light bars have such ugly switches.
  12. May 26, 2022 at 6:41 PM
    #52
    daveeasa
    David
    PNW
    OK, bit of a crazy stretch but there's a small chance I might get back into this over the weekend. I'll let you guys know. It'd be nice to get something done which could be a bit of a universal custom switch harness.
  13. Jul 10, 2022 at 6:24 AM
    #53
    Tacoblaster01
    01 tacoma
  14. Jul 10, 2022 at 6:28 AM
    #54
    daveeasa
    David
    PNW
    I never did get started on this. Hah. I am started on a full solution for @mynameistory and 4 runner headlights.
    Rather unreliable I am on this topic. Keep bugging me I guess? The on menu stuff keeps coming in and that is always first priority since the money has already been paid.
    mynameistory likes this.
  15. Jul 10, 2022 at 6:38 AM
    #55
    Tacoblaster01
    01 tacoma
    @daveeasa totally understand. I can send over a deposit if you like. Let me know we can work something out.
  16. Jul 10, 2022 at 6:42 AM
    #56
    daveeasa
    David
    PNW
    The stress of having money won’t help. I did honestly forget about this. I can put a note on my workbench to remind me. I have pockets of time once in a while but they aren’t frequent.
  17. Jul 10, 2022 at 10:15 AM
    #57
    Tacoblaster01
    01 tacoma
    I'll keep bugging ya every now and then in case you forget. Thanks @daveeasa
    daveeasa likes this.
  18. Jul 11, 2022 at 12:15 AM
    #58
    daveeasa
    David
    PNW
    @Tacoblaster01 gave me a good reminder of why I just don’t do this anymore. Spent about 6 hours I didn’t really have. Me == slow I guess. Anyway, DM me a shipping address and I’ll send this out. It tests out good with the 2 button switch I have so I’m guessing it should work ok.
  19. Jul 18, 2022 at 6:12 PM
    #59
    Tacoblaster01
    01 tacoma
    Hey @daveeasa wanted to say I did receive your harness setup last week. I left out of town same day it showed up. I'm in the middle of buying a bobcat so hopefully in a week or so I'll let you know how it goes. Thank you sir
  20. Feb 10, 2024 at 10:52 AM
    #60
    TonyM825
    TonyM825 New Member
    Tony
    2018 Cement Grey Tacoma TRD Sport
    Did you ever find a fix for this? im having the same issue with my drl lights i dont know how to plug them into my AuxBeam controller.
