wiring short - truck won't start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by darkyota33, Apr 11, 2019.
  1. Apr 23, 2019 at 11:51 AM
    #81
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Good catch .Didn't even notice that . OP ? Reason ?
    @darkyota33 Just noticed pic of two batteries on other post one was a different truck lol. That's why I was talking about taking pics .Thought you forgot were it went .My bad:facepalm:.Still good to take pics sometimes if you not too sure though
    darkyota33[OP] likes this.
  2. Apr 23, 2019 at 11:57 AM
    #82
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Might be a good idea to look at another Tacoma and check your wiring over . Now getting old lol so sometimes when I take things off I take a pic so my old mine don't get confused . No shame taking pics or labeling wires so It goes back were it suppose too.
    Nopro and darkyota33[OP] like this.
  3. Apr 23, 2019 at 11:59 AM
    #83
    darkyota33
    darkyota33 [OP] Well-Known Member
    AJ
    Upstate NY
    '05 TRD Sport, 4x4 Manual 6 spd trans, Black.
    Replaced engine with an '07 FJ Cruiser motor. Clutch accumulator deleted. WIP. plan to add new exhaust, cold air intake, URD short throw shifter,
    right, I had one there. screw is all stripped, hole is rusty and bad. and I don't have that cable anymore. ruined the eyelit trying to take it off.
    need to pick up some more of those and some cable and resecure that one.
    bought a new assembly from Napa that had the small wire and the big one coming out of one clamp, but it didn't have enough length on the big wire to go down to the block near the starter.
  4. Apr 23, 2019 at 12:02 PM
    #84
    darkyota33
    AJ
    Upstate NY
    cable was all frayed and broke. Tried to fix with a replacement wire but it didn't work.
    the black cable was my attempt at a making a ground wire. Was going to put it in the original location, but the truck was still shorting.
    bridging that higher fenderwell battery ground, with the head lights ground helped keep the circuit in tact? idk. all I know is that one was loose, and I only have one spot to screw into.
  5. Apr 23, 2019 at 12:14 PM
    #85
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    I would try to remount at original mounting point .More solid .Then nut and bolt other ground .
