Wiring the daytime running lights to an led strip?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gerrydi69, Apr 19, 2017.
  1. Apr 19, 2017 at 10:06 AM
    Gerrydi69
    Gerrydi69 [OP] New Member
    2006 Tacoma prerunner
    I have a 2006 Tacoma prerunner with daytime running lights that burned the light itself.I replaced the headlights with the halo look. And it has an led strip I would like to wire as the daytime running lights.Any help is appreciated.
  2. Apr 20, 2017 at 10:47 PM
    caribe makaira
    Caribbean, Puerto Rico
    DTRL are the turn signals on a 2006. It's controlled by circuit inside a box in the cab. In saying that once you turn headlights ON you'd loose the LED's, but they's come on when you use the turn signals.
  3. Apr 21, 2017 at 5:15 PM
    Hojae84
    Hojae84 Well-Known Member
    Bedford NY
    2008 dcsb 4x4 sr5
    Curtis home pro, front rear cameras, side blind spot cameras and more
    If you are referring to aftermarket drl?
    Then u can use a dpdt relay w 5 pins
    85- ground
    86- headlights
    30-IGN+V
    87a-DRL+
    87- no connection
    This setup should have ur drl on at ignition if headlights aren't on
    If headlight are on the drl is off
