Wiring tow harness on a first gen.
Discussion in 'Towing' started by futuretacoowner, Nov 3, 2011.
  1. Nov 3, 2011 at 2:14 PM
    futuretacoowner
    futuretacoowner [OP] Well-Known Member
    Andrew
    Canada
    02 2.7L xtra cab
    So my trailer wires don't work anymore. I was wondering where to find the wiring diagram. I checked the towing bible and the link didn't work.
  2. Nov 3, 2011 at 2:17 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    its a pain in the dick if i recall correctly. its a 5 wire system, and you will need a special plug or a converter.
    If i recall toyota had a recall on the wiring harness though as there was an issue.
    On mine, the same wire controlled the brakes/driver side blinker, then theres passenger blinker, ground, and driving lights. Forget the order and colours though. might try the fcm on ncttora.
  3. Nov 3, 2011 at 2:18 PM
    futuretacoowner
    Andrew
    Canada
    02 2.7L xtra cab
    yup I got the converter. I'll go check TTORA
  4. Nov 3, 2011 at 2:19 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    yuppers. the converter should say on it what wire, then you can simply go get the wire/run your own from the source. I do remember though like i said that the brake/driver turn are on the same which is a bear if you attempt to wire a 4 pin like i did. so i chose no driver side turn, as i wanted break lights.
  5. Nov 3, 2011 at 2:26 PM
    futuretacoowner
    Andrew
    Canada
    02 2.7L xtra cab
    Which fuse does the tow wiring harness run on?
