Wiring up new switch panel - Disconnect power when vehicle locked?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Iridium89, Dec 3, 2022.
  1. Dec 3, 2022 at 10:52 PM
    Iridium89
    Iridium89 [OP] Well-Known Member
    Aleem
    Fort Collins, Co
    2020 Voodoo Blue Tacoma TRDOR
    Fox2.5 RR DSC, Deaver Stage 2, Total Chaos UCAs, BAMF Hybrid front bumper, 12k winch, DiodeDynamics lights, SmartCap, Sherpa Cab Rack, RCI Sliders and underbody armor
    I recently picked up a switch panel and am exploring where I want it to draw power (acc power for the panel itself). I know I can tap directly off the battery or an ignition source but that's not what I'm looking for. Ideally I want to tap off a source that cuts power once the vehicle is locked. My motivation for this is I want to power down the switch panel at night when I've gone to bed and locked the vehicle while camping, but while I'm getting into the fridge or the bed (vehicle unlocked) be able to run auxiliary lights,
    I've thought about tapping off security system but that would likely be powered off until locked (opposite of what I want). I've also considered tapping off of the interior lighting system but im unsure whether the time out of the system would cut power.
    I am hoping someone might have some insight before I spend the day poking around the fuse box with a Multimeter locking and unlocking the car 100 times. TIA
  2. Dec 3, 2022 at 11:20 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Wire up a SPDT (single pole double throw) relay. Ignition power for the relay coil. Connect whatever you want powered on when the truck is off to the NC (normally closed) side of the relay. Input can just be battery power.
    Iridium89[OP] likes this.
  3. Dec 4, 2022 at 7:04 AM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
  4. Dec 4, 2022 at 8:32 AM
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    Use the voltage sense and timer functions on something like this...
    https://www.egismobile.com/shop/2602b-pdm-14-circuit-ground-175-a-12-v-5499#attr=
    No need to tap into any wires on your OEM harness.
    This particular one has three zones that can be set to either "ignition/voltage sense", Timed, or constant power and you can change the timer length for each zone as well.
    Iridium89[QUOTED][OP] likes this.
  5. Dec 4, 2022 at 11:33 AM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    Have you done business with this company? Seems like they are on point with their business model, for lack of better words, wiring.for Dummies.
  6. Dec 4, 2022 at 11:38 AM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
  7. Dec 4, 2022 at 12:01 PM
    buckmaster243
    Buck
    Washington
    Not on a Toyota but they are a very reputable company. They make complete wiring harnesses for classic car restoration, engine swaps, trans swaps, and stuff like that. I’ll be ordering that kit I linked for my 84 Chevy that is getting LS swapped.
