WIRING UP REVERSE LIGHTS UNDER BED
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LuckeyTRD, Nov 1, 2010.
  1. Nov 16, 2010 at 8:07 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Gotcha.
  2. Nov 16, 2010 at 8:16 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    what led tailgate bar is that?
  3. Nov 16, 2010 at 8:27 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    Same
  4. Nov 16, 2010 at 8:55 PM
    BeardedWeirdo
    BeardedWeirdo Junior Mint
    Texas
    2010 AC SR5 PreRunner
    Barcelona Red Pop & Lock, Tint, New Shoes, Removed Rear Headrests, Grille(in the works)
    Rampage 49".
  5. Nov 18, 2010 at 4:56 PM
    DaveSmith
    DaveSmith Active Member
    Dave
    Maine
    2010 Tacoma TRD Offroad
    Did you find out which of the 7 wires in the stock 7 pin towing harness to tap to get your backup lights to work?
    "I'm doing the same thing, and I'm planning on running them through my trailer wires. Both my cousins and friend have done it on their fords and chevys. But which wire on the tacoma trailer harness is the reverse light? Chevys have a tag with a diagram of each wire but my truck doesnt."
  6. Nov 18, 2010 at 4:57 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i forget which it was but use a tester.....5 mins and your good to go
  7. Nov 18, 2010 at 6:43 PM
    DaveSmith
    Dave
    Maine
    In regards to a 2010 DB Cab:
    I've tested all the wires/pins in my 7 pin factory tow harness and non of them become hot when the truck is in reverse. The "Battery +" (black) and "Tail Lamp" (Green) remain hot at all times. I think I need the "Back Up Lamp" (center, yellow wire) for the install of my backup lights into the factory tow harness. All the fuses in the cab and under the hood are good.
    Does anyone know if there is another fuse (not listed in the owner's manual) that connects the "Back Up Lamp" ? I read somewhere that the 2004 and 2006 had this extra mystery fuse located under the driver's seat.
  8. Nov 18, 2010 at 7:31 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
  9. Dec 10, 2010 at 8:55 PM
    DaveSmith
    Dave
    Maine
    Mystery solved: I had a bad relay. Dealership fixed it under warranty. The center (yellow) wire in the 2010 stock 7 pin connector is the trailer backup lights with relay and dedicated fuse.
  10. Dec 12, 2010 at 1:13 PM
    747
    747 function > form
    1st Gen.
    This is a slick setup on a 4runner...
  11. Dec 12, 2010 at 1:41 PM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    This is what I did to mine. Brought a 'hot' wire from the battery (well, off a wire that's powering my front aux lamps) to the back. Grounded the lights. Tapped the driver's side reverse light, through a relay and to the new lights as the on/off. Tight fit for everything.
    BTW, not real happy with the results. those walmart cheapies are certainly 'spot' type of lights. I don't know that I got much in the way of lighting. Thinking of just scrubbing them with some sandpaper and seeing if I can make them flood-lights. Anyone try that?
