wiring up some PIAA lights. got any tips?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PreRunner, May 11, 2010.
  1. May 11, 2010 at 6:19 AM
    PreRunner
    PreRunner [OP] Well-Known Member
    i tried searching but cant find what im looking for. is there a sticky or something with the best way to wire these PIAA's up to my avid light bar/2010 taco? want to do it once, and do it right. i just got my 520 ATP's in, and also got an OEM toyota fog toggle switch (00550-35976). :eek:
  2. May 11, 2010 at 10:25 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Did the lights come with a wiring harness? If not, 4wheelparts sells wiring harnesses that come with everything you will need and instructions.
  3. May 11, 2010 at 10:40 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    His set should have come with everything to do the install including directions and the wiring harness. I know because my set did at least. Only party he needs to figure out is how he is going to run the wire to the avid light bar.:rolleyes:
