Wiring?
Discussion in 'Lighting' started by zomg, Feb 12, 2016.
  1. Feb 12, 2016 at 5:55 PM
    zomg
    zomg [OP] Well-Known Member
    NOLA
    08 PreRunner SR5
    TRD CAI, Ultra-Gauge, All Weather Floor Mats, Rear Spring TSB, Avid Offroad Sliders, Spidertrax, Dynomax Superturbo, Bolt-on Grille
    I am moving from 3 Hella 500 lights to 6 LED pods. Can I use the same wiring, or should I just get a new harness? If so, how do I rewire it? The pods have a positive & negative, while the Hellas have a blue ground & a black power wire.
  2. Feb 14, 2016 at 5:32 PM
    zomg
    NOLA
    08 PreRunner SR5
    Anyone?
  3. Feb 14, 2016 at 5:38 PM
    Manwithoutaplan
    ID
    Just buy some red wire and use the black wire for the ground.
  4. Feb 14, 2016 at 5:41 PM
    Manwithoutaplan
    ID
    if you are still having doubt i have two wire harness if you want one.
  5. Feb 14, 2016 at 5:46 PM
    zomg
    NOLA
    08 PreRunner SR5
    Thanks, I'll give that a shot.
  6. Feb 14, 2016 at 6:43 PM
    zomg
    NOLA
    08 PreRunner SR5
    Uh, didn't this just say "you can run the positive through the blue wire."
    The black wire connects to the relay & blue is the ground. I'm just trying to avoid pushing wire through the firewall & figuring out what wire goes to what post on a stock fog light switch again. Because it was a pain in the ass.
  7. Feb 15, 2016 at 4:20 AM
    jarett92
    jarett92 Well-Known Member
    Jarett
    Raleigh, NC
    As long as you have positive and negative wires the color doesn't matter...I don't see why you would need to run new wires.
  8. Feb 15, 2016 at 4:40 AM
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    They are saying to run new wires because you asked if you should change the harness I guess, but I would say you will need a harness because all the connectors for the LEDs are different unless you're just have wires coming out of the pod? I would wire pods all connected together nearer to the switch. Put a fuse before the switch then run power wires from battery to switch. You may need a relay am before the switch as well depending on power draw from your 6 pod setup
