Wiring!! ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gregzz, Feb 2, 2017.
  1. Feb 2, 2017 at 10:49 AM
    gregzz
    gregzz [OP] Well-Known Member
    greg
    las vegas nv
    2011 tacoma crew cab 4x4 v6 4.0
    Wheels/ tires, tint, level kit. Rock crawler rails. 3- 6" procomp lights with light bar on front bumper. Magnaflow # 12256 stainless muffler. Billet shorty antenna.
    Stupid question. I know. But I know NOTHING about electrical. I can do almost anything else but electrical is NOT my strongpoint so here's my question.
    I've wired 3- 100 watt off-road lights to my push bumper on the front of my truck.
    I have no problem with the 3rd light as it's all by itself and the wiring is going to its own relay on the inner fender wall BUT the other 2 I'm cornfused on!!
    Do I take both wires (from the 2 lights) and splice the wires, tie them together, put on a butt connector and then add a single wire to the other end of the butt connector running that single wire to the Relay to get both lights to turn on when I flip the switch or do I need to run both wires (for the 2 lights) to the relay and then attach them to the relay individually without wrapping them together????? I'm beyond cornfused so a little input would be greatly appreciated. Sorry if this is a retarded question but I'd rather ask and look stupid than melt my truck down to a puddle of plastic. Ha ha. Thanks for any help guys. Cheers!!
  2. Feb 2, 2017 at 10:50 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  3. Feb 2, 2017 at 10:51 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Code:
    Light     Light
            Y
          Relay
  4. Feb 2, 2017 at 10:54 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    100 watts at 12v means 8+ amps per light. You need to know whether the wire you are using is capable of 25+ amps (10 gauge, preferably larger). Also ensure the relay is capable of handling the current.
  5. Feb 2, 2017 at 10:56 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    16amps Check your math on my previous post
  6. Feb 2, 2017 at 10:56 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Basically, you can make a Y wire coming from the relay to the lights (of course the legs will be different lengths for light placement). Solder and heat shrink all connections. Where the wire that is on the lights connects to the Y, I would suggest using a weather proof connector or use bullet and receptical connectors with marine grade heat shrink. That way you can remove the lights if needed without having to cut wires.
    Also, don't use the cheap relay, get one that is weather resistant.
  7. Feb 2, 2017 at 10:57 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    more redundant info, this time with pics
  8. Feb 2, 2017 at 10:57 AM
    azreb
    azreb Geezer
    TN
    I read 3 lights in the original post. It would be 16 amp for the second two, but the feed to the relay would see 25 amps.
  9. Feb 2, 2017 at 10:58 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    If all 3 are tied together yes.
  10. Feb 2, 2017 at 11:03 AM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    @Sandman614 has good references. If all 3 lights go to the same relay, make sure the relay and wiring can handle MINIMUM 25 amps, I'd recommend going up a bit to a 30 amps. If you want to overkill, like I do, I would put a 30 amp fuse on the hot wire between the battery and relay. And then 10 amp fuses on each hotwire going to each individual light.
    Sandman614 likes this.
  11. Feb 2, 2017 at 11:06 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    *side note I have actually seen this.
    BR Pipke and VangaSTL[QUOTED] like this.
  12. Feb 2, 2017 at 11:08 AM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    just remember the formula watts/volts = amps. All automotive (with the exception of rare cases) are 12v DC. So if your lights are 100 watts. Your gonna plug in 100/12 which equals 8.33 amps.
  13. Feb 2, 2017 at 11:10 AM
    azreb
    azreb Geezer
    TN
    +1. Back in my working days, the military derating guidelines for component ratings would have required more like 50 amp rating for the relay contacts for reliability, as I recall.
  14. Feb 2, 2017 at 11:13 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    That's why I like that Ampacity chart from the coast gaurd. It has a 10% non-critical rating which covers most things on our trucks, and 3% critical rating which if you're just anal you can use.
    VangaSTL likes this.
  15. Feb 2, 2017 at 11:14 AM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Ya I could see putting in a 50 amp relay. But just to clear things up your not recommending using a 50 amp fuse, that would be a bad idea.
  16. Feb 2, 2017 at 11:15 AM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Ya that's a great chart. I downloaded it.
  17. Feb 2, 2017 at 11:49 AM
    gregzz
    greg
    las vegas nv
    I have 2- 25 watt relays. One relay is running one light. The 2nd relay is running the other 2 lights. I have one switch in the cab operating 2 lights and the other switch just operating the one light. Sooooo. I think from what im being told here, I'll splice the 2 wires into one wgoing into a butt connector and from the other end of the butt connector run that single wire back to the relay. Right?? I'm sure it's simple to some but man am I confused. Lol
  18. Feb 2, 2017 at 11:51 AM
    gregzz
    greg
    las vegas nv
    Perfect. Exactly what I needed. Thank you!!!!
  19. Feb 2, 2017 at 1:04 PM
    badger
    badger Well-Known Member
    07 SR5
    This is the story right here. Excellent post Sandman. I always design around a 2% voltage drop. Even on something "noncritical" like a light, a 10% drop will be seen in the performance! The 3% numbers will be fine. OP- remember that the wire size you need is dependent on both the current (amps) and the length of run. The longer the length of the wire, the bigger it has to be. This chart allows you to see that. I don't generally solder connections unless they are critical electronic applications. A good quality crimp is fine IMO. I would be sure and use waterproof connectors.
  20. Feb 9, 2017 at 12:14 PM
    gregzz
    greg
    las vegas nv
