WisCOMMsin
Discussion in 'Mid West' started by ajmogen, Apr 6, 2021.
  1. May 26, 2021 at 5:48 PM
    #101
    Shellshock
    Iowa
    This is my new toy
  2. May 26, 2021 at 6:52 PM
    #102
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    DMR? we have a gateway in town. It's pretty neat
  3. May 26, 2021 at 7:40 PM
    #103
    Shellshock
    Iowa
    Yep
    it’s got pretty much everything
    https://powerwerx.com/anytone-at-d878uvii-plus-dmr-gps-aprs-bluetooth
    I haven’t done much with it yet. In typical fashion the programming software looks like it’s from the 1980s and isn’t super intuitive / documented / user friendly.
  4. May 28, 2021 at 4:12 PM
    #104
    Shellshock
    Iowa
    Radio is unlocked and set to proper frequency range.. finally.
    also got my DMR ID. Which after wasting an hour, discovered I actually was already assigned one and didn’t know it. Completed verification while I was at it.
    Just need to get my channels moved over and I’ll be set.
    BEAR_KNIFE_FIGHT and ajmogen[OP] like this.
  5. May 29, 2021 at 2:56 PM
    #105
    ajmogen
    ajmogen [OP] Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    Rhino Rack antenna mount installed and antenna tuned. Quick job turned in to all day shit show20210529_165323.jpg
  6. Jun 4, 2021 at 1:21 PM
    #106
    BookieBob
    BookieBob Beer Drinker
    Racine,Wisconsin
    2021 Silver Sky TRD Sport 4WD MT
    Amazon delivery on a Friday!
    Camerasandcoffee and ajmogen[OP] like this.
  7. Jul 4, 2021 at 9:42 AM
    #107
    McSpazatron
    McSpazatron Well-Known Member
    Hey all,
    Maybe a radio guru can help. Recently a buddy of mine said he couldnt hear me on the radio. Sure enough, when he i listened to his radio while I transmitted, all you could hear was what sounded like a whale call. The pitch of the tone changed if i extended or moved my mic. If i talked real loud, you could just barely make out a voice through the whale call tone.
    throughout all this time I could receive clearly... it’s just that i cant transmit.
    Im running a roof mounted firestick antenna, properly tuned. 18 ft of coax routed along the back hatch weatherstripping, and it enters the 4runner at the bottom of tge door pinched by the weatherstripping, but not tightly.
    any thoughts?
  8. Jul 4, 2021 at 10:00 AM
    #108
    ajmogen
    Aaron
    Wisconsin
  9. Jul 26, 2021 at 5:40 PM
    #109
    Supr4Lo
    Supr4Lo Well-Known Ken
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 35's
    @ajmogen Put me down for CB and GMRS.
    Last weekend installed the Midland MXT275. Seemed like the reviews were good so I'll give it a try.
    Did a semi-permanent install, fit nice in the center console. There was a slot in the bottom of the conse under the felt big enough to run the antenna cable and power wires. So no holes were drilled. Used a fuse tap to pull power off the USB circuit (I never use those buried in the console). With the Mic extension cable I can still have the tray in the console and close the lid.
  10. Oct 1, 2021 at 5:29 AM
    #110
    Supr4Lo
    Surprise, AZ
    @ajmogen how did you run your antenna cable? Under the A-pillar windshield trim? Is there room for 2 under there? Now that I have a roof rack I want to move my antennas up there.
    ajmogen[QUOTED][OP] likes this.
  11. Oct 1, 2021 at 5:30 AM
    #111
    ajmogen
    Aaron
    Wisconsin
    Yes
    No
    Cool!
  12. Apr 4, 2022 at 8:06 AM
    #112
    McSpazatron
    where did you run your antenna through? Through the firewall? Those antennas have pretty chunky ends dont they?
  13. Apr 4, 2022 at 8:30 AM
    #113
    Supr4Lo
    Surprise, AZ
  14. Apr 4, 2022 at 8:34 AM
    #114
    McSpazatron
    ok good to know. I dont know nothin about birthin no babies, which is what I was imagining it would be like running a cable it a big honking connector on the end.
    Did you have to buy the cable separate from the ghost antenna well?
  15. Apr 4, 2022 at 8:40 AM
    #115
    Supr4Lo
    Surprise, AZ
    That whole setup is history now, changed it up a while ago (the version of MXT275 I got didn't do split tones and local repeaters are using that). But what your referring to, I had bought a kit from midland that included everything. It was a nice radio and they have since added the features it was lacking.
    Newest version of what I did have at the time I posted here
    https://midlandusa.com/collections/bundles/products/mxt275vp4-micromobile-two-way-radio-bundle-1
    Now running this radio
    https://www.buytwowayradios.com/wouxun-kg-1000g.html
    with this antenna
    https://www.amazon.com/Laird-Techno...d=1649087253&sprefix=etrab4503,aps,203&sr=8-1
  16. Apr 4, 2022 at 9:13 AM
    #116
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    thats a lotta dollars for a gmrs radio. any thoughts of going to uhf/vhf any time soon?
    Shellshock and Supr4Lo[QUOTED] like this.
  17. Apr 4, 2022 at 9:18 AM
    #117
    Supr4Lo
    Surprise, AZ
    I agree it is, but the KG1000 can monitor two channels at once. I usually have two local repeaters on. If I were to do it again I probably would buy something less expensive.
    I have the study material for the HAM test just have to get off my butt and do it.
  18. Apr 4, 2022 at 10:35 AM
    #118
    Shellshock
    Iowa
    That was my thought. That’s more dollars than my icom was
    Supr4Lo likes this.
  19. Apr 4, 2022 at 10:43 AM
    #119
    ajmogen
    Aaron
    Wisconsin
    @BEAR_KNIFE_FIGHT what antenna mount (hood mount) do you have?
    Do you have it installed?
    BEAR_KNIFE_FIGHT likes this.
  20. Apr 4, 2022 at 2:52 PM
    #120
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
