Wisconsin area events- TIGERTON AUGUST 8-10!!!
Discussion in 'Mid West' started by Thatbassguy, Jul 27, 2019.
  1. Jan 7, 2022 at 1:00 PM
    #3161
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Just for you @McSpazatron...
    So I just did it on my old spare. I Debeaded it then used starting fluid to rebead. I had to give it a little kick to help it seat. Guessing needed more spray.. I tried to take video but it was hard, and I suck lol.. but here's a link to the crappy video that you'd think Michael J Fox took.
    Edit - Video link removed.
  2. Jan 7, 2022 at 1:35 PM
    #3162
    Camerasandcoffee
    Camerasandcoffee 900hp short of 1000hp
    Jonathan
    Racine WI.
    2019 Trd Sport
    Relentless Fab hybrid bumper, 2.5” Dobinsons IMS lift, RCI skids and sliders, block heater. Painted FJ Steelies. Was trying to keep it stock, now slowly building for the Wisconsin trails.
    I think I watched that same video. I've only gone down to around 16-17 psi on my stock tires. I am also hesitant to go lower than about 15. If nothing else I figure it will be a good time to use my traction boards and tow strap.
  3. Jan 7, 2022 at 2:02 PM
    #3163
    Camerasandcoffee
    Jonathan
    Racine WI.
    2019 Trd Sport
    I've had to do it to seat riding lawnmower tires. It's pretty scary, but works well.
  4. Jan 7, 2022 at 3:01 PM
    #3164
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    I’ll take videos!
    Thatbassguy[OP] likes this.
  5. Jan 7, 2022 at 3:38 PM
    #3165
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    NO, the "poof" is sucking all the oxygen out of the tire,
    the trick is the right combination of fluid and flame front.
  6. Jan 7, 2022 at 3:52 PM
    #3166
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Lol! Nice video! :rofl:
    Hat's off for making it work! It's good to know someone in the crew has successfully pulled it off. :)
  7. Jan 7, 2022 at 3:58 PM
    #3167
    Supr4Lo
    Surprise, AZ
    I'd never make it In Hollywood lol.
    After all the talk had to try it, and I was home unsupervised :thumbsup:
  8. Jan 7, 2022 at 4:20 PM
    #3168
    Thatbassguy
    James
    No roommate to talk you out of it?
    BookieBob likes this.
  9. Jan 7, 2022 at 4:28 PM
    #3169
    Supr4Lo
    Surprise, AZ
    Sent her to work for the day. Have to fund the hobbies :D
  10. Jan 7, 2022 at 7:21 PM
    #3170
    Shellshock
    Iowa
    I’ve run both my trucks down to 10. Only way you toss a bead is doing something dumb like going too fast or lots of side pressure
    tundra is real nice at 12-15
  11. Jan 7, 2022 at 8:43 PM
    #3171
    Thatbassguy
    James
    Thank you for the input. Is that what you'd recommend in snow? We shouldn't really be doing anything to put a ton of pressure on the beads, but there are some rocks mixed in.
    I was thinking about starting at 15, and dropping more if needed.
    What size are you running on the Tundra?
  12. Jan 7, 2022 at 10:11 PM
    #3172
    Shellshock
    Iowa
    Depends what you are doing. Once it gets cold and snowy, I usually run 25-30.
    playing on rocks, I’ll usually go around 15
    tundra is whatever the stock size is, I just swapped them to falkens of the same size
  13. Jan 7, 2022 at 10:28 PM
    #3173
    McSpazatron
    McSpazatron Well-Known Member
    Fricken epic you decided to do this lol. :bowdown: :101010:
    So it seems a fair amount of spray was needed. Did your kick at the end cause the gas inside the tire to combust?
    Or was it that it already poofed but it didnt seat?
    Or did it actually poof twice?
    I did not see any limbs or appendages on the ground, so from the safety of my keyboard, I declare this method both viable, and safe for emergency use.:p
  14. Jan 7, 2022 at 10:42 PM
    #3174
    Thatbassguy
    James
    We'll be on roads and trails with packed snow. Some areas might be deep, but I don't know how much snow they've gotten up there so far, and how much has melted. Areas that don't get any traffic all winter will probably be the most interesting.
  15. Jan 7, 2022 at 10:46 PM
    #3175
    McSpazatron
    interesting…but are there combusted gases (CO2) left over inside the tire, after it seats, that result in pressure?
    I guess Im wondering if too much spray can cause a tire to explode from too much air/gas pressure.
  16. Jan 7, 2022 at 10:59 PM
    #3176
    Thatbassguy
    James
    I wonder the same thing. I haven't heard of it happening, but I haven't really looked into it that much.
  17. Jan 7, 2022 at 11:23 PM
    #3177
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    Not that I know of, it's not really CO2 just the lack of oxygen inside the tire,
    I have seen ATV tires grow to twice their size for couple seconds and return to normal as the fire goes out, but still needed psi air to inflate them.
  18. Jan 8, 2022 at 12:33 AM
    #3178
    McSpazatron
    That sounds terrifying. But again, @jstemp proved it was perfectly safe judging from a lack of shrieking and lost body parts.
    I have to say, I really liked the bugs bunny style fuse jstemp sprayed down so you dont have to be as close to it when it lights off. We think alike :)
    Thatbassguy[OP] and Supr4Lo like this.
  19. Jan 8, 2022 at 3:22 AM
    #3179
    Camerasandcoffee
    Jonathan
    Racine WI.
    2019 Trd Sport
    From a few times I have had to do this, yes there is residual pressure inside the tire. The tire still needs to be inflated to proper pressure so this isn't something you can do with the weight of the truck on the deflated tire.
    Also depending on how much accelerant is used you may have to quickly put out a burning tire.
  20. Jan 8, 2022 at 4:38 AM
    #3180
    Supr4Lo
    Surprise, AZ
    It only poofed once, if you can hear past my heavy breathing at the end you can hear it. I had to give a kick to get the inside to combust. Even though the bead was off it was tightish around the rim.
    After the bead was seated there was no pressure in the tire. I would assume residual pressure comes down to how much spray is used.
    Got all appendages, I know hard to tell, by the video you'd think I lost a leg or two lol.
