Wisconsin area events- TIGERTON AUGUST 8-10!!!
Discussion in 'Mid West' started by Thatbassguy, Jul 27, 2019.
  1. May 7, 2025 at 11:51 AM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    Where do you get the cribbing from?
  2. May 7, 2025 at 12:23 PM
    McSpazatron
    McSpazatron Well-Known Member
    Hell if I know. Wood is expensive. Probably cheaper to get 6 ton stands…
  3. May 7, 2025 at 1:06 PM
    Stoney Ranger
    Stoney Ranger Pizza Cutters, Baby... and Lockers? Pffft
    Dave
    Driftless Area
    '18 Nauti Blue 4Runner SR5
    Full Armor-F/R Bprs Winch-ALF-Stickers
    Not that this info will help, but last year Northern Tool had 6 ton jack stands for $37 a pair. I bought 2 pair. If nobody else has jack stands for mod day on the 25th, I can drop them off at @Pixeltim's before I head to the Last Frontier. Lemme know.
  4. May 7, 2025 at 2:33 PM
    Pixeltim
    '15 Black DCLB SR5
    You should probably drop them off since you might never return…
    Just saying.
  5. May 7, 2025 at 2:36 PM
    Stoney Ranger
    Dave
    Driftless Area
    I'll drop them off next time I'm in Madison.
  6. May 7, 2025 at 3:01 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    I'm sure Dave has lots of stuff we can hold on to.
    Just in case.
  7. May 7, 2025 at 4:04 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I am unaware of that term as of the voice texting of my reply. Lol
    Now I can guess what that term means. :D And yes, 6 ton stands are probably much better. I just had a bunch of old crap lying around from the shop so that's what I use.
  8. May 7, 2025 at 4:12 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    That's what I thought...my measurements before my new leafs and tires showed that the 3 ton would only work on the frame with blocks under them. For a few bucks, I prefer jack stands on solid ground.
  9. May 7, 2025 at 5:45 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I mean I'm still doing it on solid ground. I'm not actually using wood or anything.
    Maybe my stands have the wrong sticker?
    Does anyone know if they ever made extended length 3 ton stands?
    Maybe mine are the recalled harbor freight ones.... :anonymous:
    bkhlrTaco's likes this.
  10. May 7, 2025 at 5:58 PM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
  11. May 7, 2025 at 6:06 PM
    OldSchlPunk
    Rich
    East Central Wisco
    With HF's specification of 16 7/8" fully extended, I guess you may get the wheels off the ground with 32s. I've never been comfortable using stands fully extended. Well, maybe my buggy, but fully assembled, it only weighed 1400# and generally wasn't on stands except to swap tires when fully assembled.
  12. May 7, 2025 at 8:35 PM
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    I'll need a report from you on places of interests - you're my Alaska scouting party :rofl:
  13. May 8, 2025 at 3:57 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    He might never return..........
    .......and that's the last they saw of @Stoney Ranger
  14. May 8, 2025 at 5:26 AM
    rockindoc75
    rockindoc75 Well-Known Member
    Brian
    Green Bay, WI
    2018 INFERNO TRD OR 4X4
    That's what I'm here for, the mods and the gear.
    I would appreciate this. I will absolutely buy a set of jacks if needed, but since I don't do major work that requires them, they would just collect dust here in Green Bay.
  15. May 8, 2025 at 5:45 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I mean, you could buy a set and sell them to me afterwards for $30 less because then they'll be 'used'. :D
  16. May 8, 2025 at 5:59 AM
    Thatbassguy
    James
    I'll have to check the two sets I have at some point. They've been working for me, but I usually jack the rear by the diff.
  17. May 8, 2025 at 6:08 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Depends on what I'm working on but I'll lift the front of the truck, take the tires off, then lower the truck onto the (3 ton) stands.
    Then I can use the jack for lca's or axles.
    I do my tire rotations 1 at a time.
    I don't trust any vehicle suspended on 4 jack stands, whether they're 3 ton or 6 ton..
  18. May 8, 2025 at 6:23 AM
    Thatbassguy
    James
    You'd probably hate the way I do mine. I put the front on jack stands, then throw the Jack under the rear diff and lift it high enough to get both back tires off the ground, and then I do all four, and then lower it back down. I also usually pull the oil drain plug after I get it up in the air and then replace it and do the filter after I get the tires rotated.
    I was just thinking I should probably change my oil tomorrow. Maybe I'll rotate the summer Tires on.:notsure:
  19. May 8, 2025 at 6:39 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Man, in H.S. I'd use logs, cinder blocks, the bottle jack that comes with the car.....
    I value life, more, nowadays. lol
  20. May 8, 2025 at 6:47 AM
    Thatbassguy
    James
    I am a little more picky if I'm going to be underneath the 4Runner. :D
