Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Aug 4, 2023 at 8:50 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    just scuff and clean, remember POR is an undercoat even says on the can to top coat after it drys.
    CygnusX191, McSpazatron and wi_taco like this.
  2. Aug 4, 2023 at 8:59 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    I've been quite happy with KBS coating that I used on my sliders (minus my own f-ups during application but that's on me). RustSeal as the protective layer like POR15, then BlackTop as the UV protective topcoat and flat finish.
    Only thing I will say is after a couple years of not running front mudflaps there are rock chips on them now but otherwise stuff has been tough as nails. Will probably pull them and touch up in winter/spring but shouldn't require stripping everything.
  3. Aug 4, 2023 at 9:02 PM
    Stoney Ranger
    Stoney Ranger Pizza Cutters, Baby... and Lockers? Pffft
    Dave
    Driftless Area
    '18 Nauti Blue 4Runner SR5
    Full Armor-F/R Bprs Winch-ALF-Stickers
    Be sure to run your gas tank waaaayyy down to greatly reduce the weight. IIRC, the drivers side slider bolts up to a tank strap. I ran my "Cruising Range" down to 5 miles. I've read of an incident where they didn't drain the tank and had a nightmare with the install.
  4. Aug 4, 2023 at 9:10 PM
    Stoney Ranger
    Dave
    Driftless Area
    Yeah. POR is a 3 step process. Use their cleaner/degreaser, then their metal etch and apply the protective coat. You need to coat the POR with paint or the POR 15 Top Coat. The uncoated POR 15 protective coat will "chalk" if left in the sun.
    Here's a vid.
    https://www.youtube.com/watch?v=8_ckBJxW6mU&t=403s
    The protective coat will look fabulous. It is self leveling and leaves a really nice finish. The POR Top Coat ruined that look. It was really difficult to work with the silver. Black may yield better finish. I used a chip brush to apply it. A better brush may have given better results. I dunno.
    Keep it away from anything you don't want coated. There is no known solvent for this stuff. Get on you and it will be there for a long while. And plan on tossing your paint brush. Which is why I used a "10-for-$12 pack" paint brush. Use a real paint brush.
  5. Aug 4, 2023 at 9:40 PM
    wi_taco
    Adam
    SE Wisconsin
    KBS is largely the same, except they have aerosol cans of the BlackTop top coat which is much much easier to deal with. But yeah don't get POR15 or KBS protective coat on anything, it isn't coming off - ever. I spilled a bunch on the garage floor, it's stronger than my old busted up concrete and is never coming off.
  6. Aug 4, 2023 at 9:57 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    When my buddy did his heep frame he used the cheap foam brushes, and a little goes along way.
    Dave is rite it does not come off of anything!
    CygnusX191 and wi_taco like this.
  7. Aug 5, 2023 at 7:13 AM
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    Another good option is Steel-It. It's expensive but incredibly stout. Prep is basically just sanding with 30 grit/40 grit or sandblasting before application.
  8. Aug 5, 2023 at 8:07 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Sandblasting and painting mine took about 4 hours, my sandblaster/compressor aren't the best. Sprayed on very easily, dried fast, looks great.
  9. Aug 5, 2023 at 8:12 AM
    OldSchlPunk
    Rich
    East Central Wisco
    Hey James @Thatbassguy, if you go to RA, when you get to gate 4, turn your head right. If you don't see Dean's @rubbersidedown truck, you're blind!
    Good seeing you last evening, Dean. Kinda felt bad blowing outta there so soon. It was a little cool when I got home, should've worn the other jacket.
  10. Aug 5, 2023 at 8:53 AM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    If you can’t find 30 grit, you can make your own by gluing gravel onto a piece of leather
    Aztec120, wi_taco, Shellshock and 4 others like this.
  11. Aug 5, 2023 at 10:15 AM
    McSpazatron
    McSpazatron Well-Known Member
    I’ve been known to drag things across a concrete driveways a time or two.
  12. Aug 5, 2023 at 10:31 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Not necessary, and super bad for your fuel pump.
    Run it to half or a quarter, but you can always support the tank with a floor jack. Or a pillow.
    Half a tank will hold up just fine with only one tank strap.
    wi_taco, r2pinter and OldSchlPunk like this.
  13. Aug 5, 2023 at 10:32 AM
    WiscoTaco4x4
    WiscoTaco4x4 Well-Known Member
    Brady
    2015 SR5 ACLB 4x4
    Someone left this on my windshield while I was at work. Kinda cool
  14. Aug 5, 2023 at 10:35 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Dude them are hard to find!
  15. Aug 5, 2023 at 10:35 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Nice! Much better then getting ducked.
  16. Aug 5, 2023 at 11:03 AM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    If this was true, I would have had to put fuel pumps in every vehicle I've ever owned. I run mine at least until the light comes on all the time, and regularly run it down to the point it says cruising range 0.
  17. Aug 5, 2023 at 11:14 AM
    WiscoTaco4x4
    Brady
    2015 SR5 ACLB 4x4
    I have 2 of them now. A family member got me one for christmas :rofl:
  18. Aug 5, 2023 at 11:15 AM
    Shellshock
    Iowa
    Yep same. Also when it says empty, there’s still like 3 gallons left. There’s still plenty there
  19. Aug 5, 2023 at 1:34 PM
    OldSchlPunk
    Rich
    East Central Wisco
    I used to do that all of the time with my 2nd gen, until the fuel pump burnt out. They use the gas to cool the pump and repeatedly running that low puts added wear into the pump. Of course, this will happen at a very inopportune time, without any warning. Mine cost $800 to replace IIRC. :spending:
  20. Aug 5, 2023 at 2:06 PM
    Thatbassguy
    James
    I do this all the time with every vehicle I've ever owned. Never had a fuel pump go due to it. Running it out of fuel completely is a different story.
    wayupnort and sparkystaco like this.
