Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Aug 13, 2023 at 10:01 AM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    I replaced the door and dash speakers with a set of JL c1-690s. Definitely a noticeable improvement over the stock flimsy speakers, and they weren't too expensive either.
    If you're not going to add an amplifier, look for speakers with a higher efficiency (usually labeled as "SPL, 1 Watt, 1 meter )rating.
  2. Aug 13, 2023 at 11:19 AM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    So, it's not normal for the transfer case to be pressurized right? I changed the fluid today and when I loosened the fill plug it hissed and then a good amount of fluid actually ran out of the fill plug. Perhaps it was already changed once before I purchased the truck and it was overfilled??
  3. Aug 13, 2023 at 12:26 PM
    Thatbassguy
    James
    That seems weird. I could see some running out if you had pulled it up on ramps due to the angle. But, the hissing seems unusual to me. But, if it was hot, maybe it's not that weird. :notsure:
  4. Aug 13, 2023 at 12:37 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Hissing tells me that it built pressure most likely through heat. Your breather might also be clogged or crimped, might be worth checking out.
  5. Aug 13, 2023 at 3:22 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    This
  6. Aug 13, 2023 at 4:24 PM
    Z7Xtreme
    Z7Xtreme Always Overestimated
    Chuck
    In a tree somewhere
    2015 trd Black Ops edition
    884's and 5100's with HS 1/4" taco lean spacer,1 inch toytec block and 5100's,SPC uca's,SCS Ray 10 wheels,265/75/16 Falken Wildpeak AT3,oem running boards,oem skid plate,WeatherTech floor liners,WeatherTech window deflectors,Access tonneau cover,WeatherTech stone and bug shield ,BPF tow hook,oem bed mat,pro grill,tacomabeast headlights,cali raised ditch brackets with Rigid lights,Rough country 30” lightbar on Rigid brackets RCI bedrack, KC rear lights,maxtrax,dual rotopax.
  7. Aug 13, 2023 at 4:35 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
  8. Aug 13, 2023 at 4:37 PM
    patfl1
    patfl1 Member
    08 4runner
    Bilstein HD's, slight lift, intake
    ‘14 manual. Frame looks great, untreated low miles and garage kept :)
    suggested i pull over the info from thread above, thanks for any input:
    Promise I looked first, nothing through Jan of 2020.
    Flying in to purchase, need a pre purchase inspection …and if all good some fluids changed before the drive home.
    Any help is greatly appreciated!
    thanks,
  9. Aug 13, 2023 at 7:59 PM
    Thatbassguy
    James
    @Supr4Lo and @rockindoc75 are in the Green Bay area. You guys know any good mechanics/shops?
  10. Aug 13, 2023 at 8:21 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Jason's closer to Milwaukee than GB.
    CygnusX191 and sparkystaco like this.
  11. Aug 13, 2023 at 8:25 PM
    Thatbassguy
    James
    Really? I always thought he was closer to Green Bay.
  12. Aug 13, 2023 at 8:26 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Sheboygan must be an hour to GB, probably half that to Milwaukee.
  13. Aug 13, 2023 at 8:28 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Sheboygan is closer to 11/2hrs to GB
  14. Aug 13, 2023 at 8:30 PM
    Thatbassguy
    James
    It's about halfway between. But, it's closer to Green Bay than I am. :D
  15. Aug 13, 2023 at 8:31 PM
    OldSchlPunk
    Rich
    East Central Wisco
    You may be closer. As I re-think it, Manitowoc is about 45 minutes to GB and Sheboygan is probably a half hour or so to Manitowoc.
  16. Aug 13, 2023 at 8:32 PM
    Thatbassguy
    James
    Only if you drive like a granny. Google says 1 hour, 3 minutes. And, just under an hour to Milwaukee.
    CygnusX191 likes this.
  17. Aug 13, 2023 at 8:36 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Well, my reference was a bunch of years doing that road with 18 (governed) wheels.
  18. Aug 13, 2023 at 8:37 PM
    Thatbassguy
    James
    What are they governed at? I swear I have seen some trucks going like 80 on the way down to Florida sometimes. That seems ridiculously fast for an 18 wheeler.
    Edit: ordinarily, it seems like they are going around 70, tops.
  19. Aug 13, 2023 at 8:41 PM
    rockindoc75
    rockindoc75 Well-Known Member
    Brian
    Green Bay, WI
    2018 INFERNO TRD OR 4X4
    That's what I'm here for, the mods and the gear.
    I haven't been to a shop since my warranty expired. Just been trying to do my own maintenance. There is a DIY shop that just opened up with tool and lifts, if that's another route you would be interested in?
  20. Aug 13, 2023 at 8:56 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    And we all know google is never wrong!!!!!!!!
