Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Oct 28, 2023 at 7:18 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Yeah..... Not getting to retire in my lifetime
    Got a few problems with this.
    1: If it ever goes to production, it'll be limited most likely only to the southern dealer groups.
    2: 21-in rims are going to suck for mounting tires.
    3: the hand bilt turbo 3.4s are excellent. The factory built ones have started their massive blow up process. Tundras are dropping like flies as people are driving them harder now. The design is good, the factory implementation cheaped out somewhere. That investigation is going to cost Toyota hundreds of millions of dollars and I cannot wait for the "we're going to replace your entire engine" recall program...
  2. Oct 28, 2023 at 8:02 AM
    Shellshock
    Iowa
    Same
  3. Oct 28, 2023 at 8:38 AM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    I'll probably have to work right until the end at this rate, also. I'm just hoping that I can switch to an easier job sometime in my 60's, like working at a bait shop.
  4. Oct 28, 2023 at 8:50 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I wouldn't mind driving that zamboni floor cleaner around Woodman's grocery. That looks like a good job.
  5. Oct 28, 2023 at 9:10 AM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    This looks promising!
    https://masterbaitandtackle.com/
  6. Oct 28, 2023 at 9:28 AM
    Thatbassguy
    James
    Good call!
    Haha!
    I think I might need to buy several of their shirts.
  7. Oct 28, 2023 at 10:14 AM
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    Always a good day when the old girl gets to stretch her legs a bit.
  8. Oct 28, 2023 at 11:02 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Cold Saturday in the Northlands... 35 and windy. Great day to take a cabless, heaterless 1932 fire truck for a spin...
  9. Oct 28, 2023 at 11:23 AM
    Thatbassguy
    James
    Haha, sounds perfect! 34° here in Downsville. I'm not ready for this yet!
    sparkystaco, CygnusX191 and wi_taco like this.
  10. Oct 28, 2023 at 12:11 PM
    Pixeltim
    '15 Black DCLB SR5
    No kidding, I pulled the hoist out of the lake just now. I should’ve done it when the water was warmer.
  11. Oct 28, 2023 at 12:22 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Did you fall in the water?
    sparkystaco and CygnusX191 like this.
  12. Oct 28, 2023 at 12:55 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Fired up the smoker on this cold day.
  13. Oct 28, 2023 at 12:55 PM
    Pixeltim
    '15 Black DCLB SR5
    Nope. Waders help, but it’s still cold
  14. Oct 28, 2023 at 1:03 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    New antenna. Trip home from the Bayfield run destroyed my short mast so I got a stubbie from Craven Speed
  15. Oct 28, 2023 at 1:10 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    We pay someone to do that... because I always waited too long to do it...
  16. Oct 28, 2023 at 1:32 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Yeah! Then you could be a master ba.... Um... Sales guy. :D
    It really is getting cold there
  17. Oct 28, 2023 at 1:43 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Nice day for a parade. Had a firetruck full of middle schoolers throwing candy.
  18. Oct 28, 2023 at 2:36 PM
    McSpazatron
    McSpazatron Well-Known Member
    Got a pair of coil spring compressors (screw type) to try and adjust my front dobinsons, but they don’t quite fit between the coils. Oh well, have a quarter inch trim spacer i got from crickey mike. I’ll install that on the drivers side instead.
    Question…. I noticed one of the top shock bolts is oval-ized a bit. I didn’t think they were loose and never made noise.
    Replace them? Are these supposed to get a ton of torque? It’s impossible to get a good angle on these to tighten.
  19. Oct 28, 2023 at 2:43 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Get new ones. They're not super expensive and a short-ish 14 mm wrench shouldn't be too hard to come by.
  20. Oct 28, 2023 at 2:55 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    @CygnusX191 didn't have some torque specs to throw out there? You feeling ok?;)
    Hand tight works for me
    and for those hard to reach areas.
    DURATECH Flex-Head Ratcheting Wrench Set, Combination Wrench Set, 72 Tooth, Metric, 12-piece, Size Covers 8-19mm, CR-V Steel, with Rolling Pouch https://www.amazon.com/dp/B08DJ3SYVN
