Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Nov 14, 2023 at 12:53 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    That's interesting, I didn't think the R value was that high per inch. Did a quick search and most sites say closed cell is about R-7 per inch. Maybe your installer meant the end result would be like R-19 equivalent or maybe the internet is wrong but I hope you get as much R as you can. Looks good.
    Curious about what your plans are for venting in regards to moisture and air quality? Looks like you have the soffets foamed in and no ridge vent. Are you going to be running a fan or some other type of roof vent?
  2. Nov 14, 2023 at 12:57 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    More R, More good but if r19 is the end result of 2" of foam then I'm changing my mind to, No, It isn't worth it.:D
    sparkystaco and CygnusX191 like this.
  3. Nov 14, 2023 at 1:00 PM
    rockindoc75
    rockindoc75 Well-Known Member
    Brian
    Green Bay, WI
    2018 INFERNO TRD OR 4X4
    That's what I'm here for, the mods and the gear.
    Sounds like it will be warmer than my first apartment when I moved to Wisconsin.
  4. Nov 14, 2023 at 1:24 PM
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    Correction, walls will be technically rated about 19R and roof deck about 21-25R.
    No ventilation needed by creating a conditioned, closed space, but I can add a dehumidifer if needed. I'll be having a powered vent installed for welding/painting, too.
    On paper, R value is more with batts. In reality, the foam outperforms batts. With the space I have, it will be perfect for my needs.
  5. Nov 14, 2023 at 1:31 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    You have to consider the foam is completely sealing air cracks.
    That alone counts for a handful of R's in my eyes. Unless that's already factored in.
    Not real up to date on how to measure R rating.
  6. Nov 14, 2023 at 1:57 PM
    wi_taco
    Adam
    SE Wisconsin
    Ahh got it, thanks. Curious to see how your venting works, it's one of those things to me that everyone in the trades has their opinions on it but they don't universally agree that you need a fan/dehumidifier in certain situations. Same goes for vapor barriers - you'd think it's voodoo based on the wide array of responses you get online and from real life contractors. Makes it hard for us home gamers to make good decisions when even the pros can't all agree on a topic.
    And yeah I agree your CCF spray goes beyond just R value, the sealing factor is way bigger than most make it to be. I think it will serve you quite well.
  7. Nov 14, 2023 at 2:24 PM
    WiscoPat
    Pat
    Wisconsin
    Mall Rated
    It would be different if I had an attic space, but I'm keeping the roof deck open.
    Ultimately I think it'll be great and I trust the opinion of the pros who have been doing it for quite a while.
  8. Nov 14, 2023 at 4:03 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Wheelers Offroad is having a 25% off sale!
    Who was it that was looking for sliders??
  9. Nov 14, 2023 at 4:42 PM
    McSpazatron
    McSpazatron Well-Known Member
    That’s definitely the cherry on top. Looks like it will be cozy warm.
  10. Nov 14, 2023 at 6:13 PM
    WiscoPat
    Pat
    Wisconsin
    Mall Rated
    I'm thinking that at least one winter mod day will be in order.
  11. Nov 14, 2023 at 6:44 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I wouldn't be able to associate with you anymore if you didn't.
    I think a healthy single digit temp day is in order. :)
  12. Nov 14, 2023 at 8:43 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    The nice thing about having the roof insulated is that any heat you use in the garage won't cook the shingles.
  13. Nov 14, 2023 at 9:22 PM
    wi_taco
    Adam
    SE Wisconsin
    Speaking of mods, it looks like the sales are steadily increasing. Good luck to your credit cards during this holiday season, my friends.
  14. Nov 15, 2023 at 10:17 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
  15. Nov 15, 2023 at 1:00 PM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    Not to try and thread slide, but I thought some of you might be interested in seeing a Taiwanese traditional market. It’s a bit long, but watch at least until you see the fresh beef and seafood! It’s unlike anything we have in the great state of WI!
    I also came across this the other day, jealous!
  16. Nov 15, 2023 at 3:58 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    So, originally I was thinking of leaving the bumper alone where it is and trim the ends off. Now, I am having second thoughts... It hits, so I was hoping to come up some and maybe even bob a bit off the frame... back to the spring perches. If I turned the bumper mounts over on top of the frame rather than the bottom I can gain 2-3 inches plus the approach angle. Its really only some time and steel, and a bit of redoing the mounts I made to strengthen the mess from the Hammer Hangers. Anyone want a silver premade Coastal Offroad bumper???
  17. Nov 15, 2023 at 4:46 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I do.
    But I'm broke :pout:
    OldSchlPunk and wi_taco like this.
  18. Nov 15, 2023 at 4:51 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    I will donate $20 towards the cause
  19. Nov 15, 2023 at 5:11 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    PM me... lets talk
  20. Nov 15, 2023 at 5:16 PM
    Pixeltim
    '15 Black DCLB SR5
    I might be interested…
    Missed it by 31 minutes!
