Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Dec 3, 2023 at 7:32 AM
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    You could fabricate a mount for the license plate and for a backup camera. I'd place both towards the top of the bed, as you just might actually test your departure angle.
  2. Dec 3, 2023 at 7:50 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    I agree with this line of thought. Higher up is better because I could see dropping off a ledge and your plate getting crinkled up again like before.
    Heres an idea: Hard mount your backup camera somewhere it won’t get smashed and then call that part done. Make a hitch mount adapter for the license plate. Then, on the top of the flatbed make some kind of small receiver mount so that when you hit the trails you can take it out of the low position and put it up high. Also, if you make the bed-mounted receiver removable you can still rock a completely flat bed when you need to have it. Modular mounting on the bed top could also be used for things like a vise which I’m sure you’d use for the bikes or other projects.
    Edit: went back and re-read your post. Received mount isn’t “letter of the law” but I highly doubt any cop is that big of a dickhead to cite you for it.
  3. Dec 3, 2023 at 8:08 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    As promised... Porn! Flatbed Porn. You have been warned.
  4. Dec 3, 2023 at 9:43 AM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    Damn is that ever coming along fast! It looks great!
    sparkystaco, CygnusX191 and wi_taco like this.
  5. Dec 3, 2023 at 9:46 AM
    Camerasandcoffee
    Camerasandcoffee 900hp short of 1000hp
    Jonathan
    Racine WI.
    2019 Trd Sport
    Relentless Fab hybrid bumper, 2.5” Dobinsons IMS lift, RCI skids and sliders, block heater. Painted FJ Steelies. Was trying to keep it stock, now slowly building for the Wisconsin trails.
    I would opine that from the places you have been and the stories you have to share that it's been a good life. Heck I haven't done 1/8 of that stuff and I'm financially no better off. :spending:
    Being a member of this brotherly yet cursed forum doesn't help. Self imposed price of being a member of the tribe I suppose.:cheers:
  6. Dec 3, 2023 at 10:24 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Donate the $15 for some, less noticeable, black Road America plates.
    It's crossed my mind a time or two.
  7. Dec 3, 2023 at 11:25 AM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    How about this: Get a set of these, like I'm using on the front of my truck https://www.amazon.com/gp/product/B0BBLHB274?ie=UTF8&th=1. I wasn't happy with how easily they moved, so I used a punch to dimple the hinges in a couple of spots to firm them up a little. You could put them just about anywhere on the down panel with a small LED light above to provide legality. When you're on the trails, a quick push would put the plate out of harm's way. A piece of 1/8" aluminum is what I used to back up the plate.
    Or, you could bend up a piece of sheet metal for a mount that could be bolted or welded on.
  8. Dec 3, 2023 at 1:47 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Thanks for all the license plate mount input. The wife even got involved. Still no legal solution that I embrace... guess i am gonna have to be an adult... Do want to through out that i am building a headache rack-can it go up high? Didn't read anything about height, just horizontal and lit. Hummmmmm....
  9. Dec 3, 2023 at 2:00 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I was looking at the legality of tinted l.p. covers, recently.
    All I found on the dmv page was "legible and visible".
    Tinted covers are most likely a no go.
    Height probably doesn't matter.
    Best bet is stop at your local law enforcement agency and ask. Their the ones that'll be pulling you over if it's not right.
    CygnusX191, sparkystaco and wi_taco like this.
  10. Dec 3, 2023 at 2:07 PM
    Camerasandcoffee
    Jonathan
    Racine WI.
    2019 Trd Sport
    I have two potential options for mounting, but first cut the plate down as small as possible. leave just the actual number and registration sticker. Option 1 next to the receiver with a heavy plate behind to keep the plate from being bent up. Lose a touch of departure angle but being so close to the spring hangers maybe it's not such an issue. Option 2 would be to cut a small box into the center angle section to mount the plate and reverse camera..
  11. Dec 3, 2023 at 2:09 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Hadn't thought of boxing into the storage area... would work and only loose storage. Hummmmm.....
  12. Dec 3, 2023 at 2:23 PM
    wi_taco
    Adam
    I'd like to change my vote to Jonathan's idea, and also propose another option. Mount on the lower bumper, bend the top of the plate at the line under "WISCONSIN" to match angle of angled box section (or cut the plate to fit). Here's a quick photoshop:
  13. Dec 3, 2023 at 3:08 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
  14. Dec 3, 2023 at 3:13 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Asymmetrical is okay? That is easy!
  15. Dec 3, 2023 at 3:18 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I like the recessed box rite above the bumper or hinged rite below the camera.
  16. Dec 3, 2023 at 4:22 PM
    OldSchlPunk
    Rich
    East Central Wisco
    and it would be a nicely shielded place for the license plate light.
  17. Dec 3, 2023 at 6:36 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
  18. Dec 4, 2023 at 6:51 AM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    I had to take a picture of my bass rig on Saturday.
    At one time, I had 2 Ampeg 4×10 cabinets, but I sold them in a moment of stupidity. When the band got back together, I bought a Peavey Black Widow 15" speaker from Uncle Bob's on Greenfield, and threw together a box for it. Later, I bought another one, and have been through a handful of different designs, including 2 different versions where both were in the same cabinet.
    I eventually decided to stop winging it, and use the specs to find the ideal volume, port size, and tuning frequency. I wound up building these two boxes, with 6" × 6" slot ports on the rear. The bottom one also has locking casters on it.
    I'm always impressed when I play through them and remember how well they turned out. I'd gladly put them against any store bought 15" bass cabinet, and I bet they would hold their own.
    The bottom one still needs the grill painted. But, anyone here who knows me already knows how I like to get a project 90% done and then just call it a day. :anonymous:
    Still, I'm pretty proud of what I did with these.
  19. Dec 4, 2023 at 7:07 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    These different license plates ideas are fun. But keep in mind.... I bet Leo's don't like plates that are chopped up.
    Nice head :wink:
  20. Dec 4, 2023 at 8:22 AM
    Thatbassguy
    James
    Thanks! :oops:
    I started out with a GK head, which I still have. I ran through that with an ADA MB1 preamp, which was endorsed by Les Claypool, so I had to have it. I actually wish it hadn't crapped out, because it was pretty awesome. Eventually, I added a Behringer power amp, and had everything in an 8 space rack, which weighed a ton!
    One day, I told my ex that I was sick of lugging it around and we needed to put some money aside for a new head.
    I had already chosen that MarkBass head. About a month after that conversation, on the way to the studio to record some stuff, we stopped at Guitar Center for drum sticks and guitar strings, and I saw that it was on sale for like $100 off. So, I called the misses to run it up the flagpole, and shockingly she said to get it.
    What impressed me right away was how much cleaner it is than the old Behringer power amp I was using before. Much more powerful, even though it was rated at lower output (800 measley watts compared to 1200). I definitely learned the difference between quality electronics and cheap junk.
    I also love that it has a little pencil tube preamp which adds a little warmth, but it also has a solid state preamp with a blend control.
    Sorry for the rant. Sometimes I forget how much I like that stuff.
