Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Dec 9, 2023 at 9:54 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    The reason I modified the frame and moved it up top is that the tire is so big and there is not enough room under without loosing serious departure angle clearance. The first thing to hit now are my hammer hangers and if it’s that steep I might want to rethink what in the actual frick I am doing…
  2. Dec 9, 2023 at 9:55 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Rack isn’t going back on
  3. Dec 9, 2023 at 10:04 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Simple solution,,,
    Just don't get a flat tire.
    I know
    I know
    That's easier said than done.
    Nothing that a can of starting fluid and match can't fix.
  4. Dec 9, 2023 at 10:15 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    The not liking hinges was a joke. :D
    I wasn't sure if, where the tire sits now, there was room to leverage something underneath to help prop it out. In the space between the tire and the cab.
    sparkystaco, wi_taco and CygnusX191 like this.
  5. Dec 9, 2023 at 10:26 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    And make sure you fluid fill in the crap out of it so it doesn't rust away under there lol
    :drool:
  6. Dec 9, 2023 at 10:50 AM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    He just likes being unhinged.
  7. Dec 9, 2023 at 11:12 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Guess it's finally official. New plate is not bent up enough though....
  8. Dec 9, 2023 at 11:19 AM
    Pixeltim
    '15 Black DCLB SR5
    Give it time!
  9. Dec 9, 2023 at 11:21 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    When is you next trail ride?
  10. Dec 9, 2023 at 1:12 PM
    Stoney Ranger
    Stoney Ranger Pizza Cutters, Baby... and Lockers? Pffft
    Dave
    Driftless Area
    '18 Nauti Blue 4Runner SR5
    Full Armor-F/R Bprs Winch-ALF-Stickers
    I was thinking weld a couple of steel tubes similar to what one would use to hold shovels, rakes, etc. on the headache rack (or drill big enough holes in the rack itself) and use a 1" bar (vertical) that has the horizontal piece attached. Use a block and tackle to raise and lower the tire. This way it could be stored with the tire. I don't have the know-how to attach the horizontal bar other than welding it. Maybe a piece of pipe that is capped and welded to the horizontal piece which would slide over the vertical piece and swing side-to-side.
    Hope that makes sense.
  11. Dec 9, 2023 at 3:01 PM
    Camerasandcoffee
    Camerasandcoffee 900hp short of 1000hp
    Jonathan
    Racine WI.
    2019 Trd Sport
    Relentless Fab hybrid bumper, 2.5” Dobinsons IMS lift, RCI skids and sliders, block heater. Painted FJ Steelies. Was trying to keep it stock, now slowly building for the Wisconsin trails.
    We sure do. Last years calendar it was pretty easy for me to pick out the ones I took. Now I'm not exactly sure. That's a good thing although it means I need to step up my game!
  12. Dec 9, 2023 at 3:06 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    How about just putting a tree saver strap thru the spokes so you can lift it out.
  13. Dec 9, 2023 at 3:51 PM
    Camerasandcoffee
    Jonathan
    Racine WI.
    2019 Trd Sport
    I do like the Cutwater cocktails. The Mai Tai is pretty decent, they go down really smooth on a hot summer day which can be a problem as they are 12%alc. @rubbersidedown turned me onto their whiskey mule at Tigerton and I try to keep some in stock at all times now.
  14. Dec 9, 2023 at 4:22 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    I'm having the White Russian now.
    It's actually pretty good.
  15. Dec 9, 2023 at 4:42 PM
    Pixeltim
    '15 Black DCLB SR5
    Would it be possible to weld a winch mount on the headache rack and use your portable winch to remove the spare?
    Stoney Ranger and sparkystaco like this.
  16. Dec 9, 2023 at 6:26 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
  17. Dec 9, 2023 at 7:14 PM
    Stoney Ranger
    Dave
    Driftless Area
    I kinda like the "just use a strap" idea.
  18. Dec 9, 2023 at 10:35 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    We have a smaller, swinging, stationary boom at work similar to what you're describing, to lift a metal cover off of a pit in the floor.
    There are 2 pulleys on the "horizontal' pc for the cable that is raised and lowered by a handcrank like you would see on a boat trailer.
    Edit: not the best pic but I knew I had one. Steel plate on floor is heavy a.f. and that boom lifts it.
    cable winds up in the box on left, removable handle connects on the right.
    sparkystaco and CygnusX191 like this.
  19. Dec 10, 2023 at 5:32 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
  20. Dec 10, 2023 at 6:02 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
