Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Jan 11, 2024 at 10:25 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    I agree you've probably hit that bumper more than tree times. Time for a nice steel one.
  2. Jan 11, 2024 at 10:56 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    :D
    :rofl: you're welcome :D
  3. Jan 11, 2024 at 11:01 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    :rofl::rofl::rofl::rofl:
    New bumper.
    Been thinking about it.
    Stock bumper is pretty stout.
    Thought for sure I would've damaged it more I did last year.
  4. Jan 11, 2024 at 3:48 PM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    You could make a sand angel. :D
    Seems appropriate.
    I see what you did there.
  5. Jan 11, 2024 at 5:13 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    You all are failing to contain the white mess to the south…. Do like these Kendas you n the slippery stuff
  6. Jan 11, 2024 at 5:43 PM
    Stoney Ranger
    Stoney Ranger Pizza Cutters, Baby... and Lockers? Pffft
    Dave
    Driftless Area
    '18 Nauti Blue 4Runner SR5
    Full Armor-F/R Bprs Winch-ALF-Stickers
    Are you in the "Liquor Store Warning" zone?
  7. Jan 11, 2024 at 7:04 PM
    Stoney Ranger
    Dave
    Driftless Area
    I should have asked if the liquor store warning has moved north.
  8. Jan 11, 2024 at 7:32 PM
    Thatbassguy
    James
    I think people hoard liquor in Wisconsin regardless of the weather.
  9. Jan 12, 2024 at 1:40 AM
    Spadi_5
    Spadi_5 Well-Known Member
    Wisconsin
    2019 DCSB TRD OR
    Absolutely.
    sparkystaco and CygnusX191 like this.
  10. Jan 12, 2024 at 4:05 AM
    Stoney Ranger
    Dave
    Driftless Area
    What tire pressure do you guys run in the snow? I've had my Falken Wildepeaks set at 40 psi since forever. Not impressed in the snow for a 3PMS rated tire. I lowered the pressure to 35 for this storm. Heading out for my Friday morning hockey game in 10 mins. We have a touch over an inch on the ground right now. Ride home should be exciting.
  11. Jan 12, 2024 at 4:24 AM
    Thatbassguy
    James
    Same as street pressure. But, I could see airing down a bit being helpful.
    I always heard that those were good in the snow.
  12. Jan 12, 2024 at 4:31 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Both of those pressures are way too high. Should be running them at like 33 in the dry and maybe 25 in the snow for actual results. Lol
    They're fantastic if you don't overinflate them to donut status
  13. Jan 12, 2024 at 4:35 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Different tires but mine never get above 34 on a hot summer day...
    30 cold.
  14. Jan 12, 2024 at 4:44 AM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    I had mine in the low to mid 30s and they were great in snow.
  15. Jan 12, 2024 at 6:07 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Kendas work fantastic down to around 8psi. After that I get debris in the beads and they leak. Time for bead lock rims…. Normal is around 35 ish. Being what they are they are a tad harsh but that is the price. Could probably get away running them in the 20’s somewhere but I would forget a tow something heavy and wonder why it’s squirrely
  16. Jan 12, 2024 at 6:17 AM
    Supr4Lo
    Surprise, AZ
    I keep saying Kendas FTW but nobody believes me. Just a fantastic all around tire.
  17. Jan 12, 2024 at 7:05 AM
    Spadi_5
    Wisconsin
    2019 DCSB TRD OR
    I’m hoping for a good amount of snow tonight and tomorrow to see how the Falkens do. Mine were set at 35 psi when I got them from Discount tire a few months back.
  18. Jan 12, 2024 at 7:34 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    I think everyone else has you covered already, but wanted to mention pressure is also going to depend on tire load range. What is good for someone with SL rated tires may not be the same for E load range. Only way to know what is best for your tires in dry conditions would be to do a chalk pattern test and then knock off a couple PSI for the wet/snow.
    If you want another data point, I run mine at like 34 year round, maybe a touch lower in the snow if I really need to. General Grabbers are damn good in snow, quite similar to what I would expect for a Wildpeak but have never had those myself. I have C load range though so it may be slightly softer compound than E loads on most 33" tires.
    Anyways, in general 40 might be too high for the conditions. You aren't going to hurt anything by dropping to 30-32 and seeing if it helps.
  19. Jan 12, 2024 at 7:38 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Didn't you get some Kenda's from Jason?
  20. Jan 12, 2024 at 7:48 AM
    wi_taco
    Adam
    SE Wisconsin
    Yes but haven't been able to mount yet because I need to do the CMC and flatten the pinch weld. Other stuff kept coming up last year but I should have them finally mounted sometime this spring.
