Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Jan 27, 2024 at 7:26 AM
    Shellshock
    Iowa
  2. Jan 27, 2024 at 8:21 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Very rarely ever use the hitch.
    Should just cut it off....
    About the time I did, I'd need to tow something.
  3. Jan 27, 2024 at 10:35 AM
    Aztec120
    Aztec120 The Road To Hell Is Paved With Stock Tires
    Cisco
    Milwaukee
    La Tortuga '17 SR5 DCSB
    Leer Topper 90% Chrome Delete
    Ran into a motherfucker of an electrical gremlin when I went to get my emissions done.
    No power to pin 16. Wire is fine, 7.5A interior fuse looked fine, otherwise I don't have a 20A for another suspected blown fuse just yet.
    I only remember having to jump some pins when I was doing my transmission fluid checks earlier this year. But I can't imagine that was enough to de-pin anything.
    To top it all off the ABS sensor I replaced a while back must have had a shitty gasket. Started acting up once all the snow was melted.
  4. Jan 27, 2024 at 10:52 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Well.... If you click on the link .... :wink:
    Flat springs on a midsize are fine. They'll still hold weight and the ride won't be terrible as if they were super curved. Remember, this isn't the 70s. Metalurgy has improved greatly. Shoot, my Dakar mediums are W shaped and puddle jumper still has its lift and weight bearing capacity.
    Why are you jumping pins to check transmission level? There's a level check embedded above the drain plug.
    Wheel speed sensor? Should have had a paper gasket, although it the mounting surface has corrosion they don't always sit right. Good luck.
  5. Jan 27, 2024 at 11:11 AM
    Aztec120
    Cisco
    Milwaukee
    Cleaned up the mounting surface this morning and still no luck. If water does make it in there does that just trip a fuse? I already have to get a 20A for the other stuff might as well get a 50A while I'm at it.
    Jumped two pins and shifted between neutral and park to get it into check mode after it got to the right temp when I was replacing the fluid.
    Trust me I wasn't completely sold at first if it really needed to be so involved just to check fluid level. 3rd gen Auto ftw :bananadead:
  6. Jan 27, 2024 at 12:44 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
  7. Jan 27, 2024 at 1:12 PM
    Stoney Ranger
    Stoney Ranger Pizza Cutters, Baby... and Lockers? Pffft
    Dave
    Driftless Area
    '18 Nauti Blue 4Runner SR5
    Full Armor-F/R Bprs Winch-ALF-Stickers
  8. Jan 27, 2024 at 1:54 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I mean... There's a level check tube that is screwed in to your drain plug port on your transmission pan. You can actually do a cold level check as well. That one's nice because you don't have to add a ton of fluid back to the system because when it's warm everything has expanded. But also on the warm fluid check level you're supposed to pin open the cooler.
    May I ask why you are checking your fluid levels? Trying to determine if you need a service or not? Debating between a full transmission flush versus a yearly drain and fill?
    Aztec120[QUOTED] likes this.
  9. Jan 27, 2024 at 2:30 PM
    Stoney Ranger
    Dave
    Driftless Area
  10. Jan 27, 2024 at 2:43 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    Took these the other night and couldn't decide if the lighter or darker one was better
  11. Jan 27, 2024 at 3:26 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    If you win the Powerball, could you pay to get my truck done?
  12. Jan 27, 2024 at 3:29 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    They were flatter before. There is some curve to them now, bad pic.
    Driveline angles changed by about 1 deg but I'm still in range. I'm not touching anything....at least until it 'settles'. if it settles.
    CygnusX191[QUOTED] likes this.
  13. Jan 27, 2024 at 3:39 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I like the liter one but I don't dislike the darker one.
  14. Jan 27, 2024 at 3:40 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    1 vote for the lighter one..
    You can see more detail in the surroundings where as the darker one is like tunnel vision.
    Though the 2nd one looks good, too. it has full focus on the light and what's ahead..,with no distraction.
    Depends on the intent of the image, I guess.?
  15. Jan 27, 2024 at 4:16 PM
    Stoney Ranger
    Dave
    Driftless Area
    Depends.
    CygnusX191 and sparkystaco like this.
  16. Jan 27, 2024 at 4:38 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    35's will make that less painful...
  17. Jan 27, 2024 at 4:44 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
  18. Jan 27, 2024 at 4:46 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    I've looked at bumpers too for a while and call me foolish, but I just am not ready to part with my BSM just yet.
  19. Jan 27, 2024 at 4:47 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Drove to Chicago yesterday. Drove back today. Stopped in Fond du Lac and had a visit with @Taco-Grinder! Good to see you and your lovely wife. Wandered over to Phiillips to try and catch my daugher swimming but missed her last heat by 5 minutes-bummer...
  20. Jan 27, 2024 at 4:47 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Depends,,,,
    On What?
