Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Jan 27, 2024 at 4:48 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    I almost added to that post tagging you because everyone (should) know that 35's are the answer.
  2. Jan 27, 2024 at 4:49 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Sorry to hear that.
    That is sorry to hear you missed your daughters swim meet.
    Had a great visit. Mary can finally put a face to a name.
    CygnusX191 and sparkystaco like this.
  3. Jan 27, 2024 at 4:59 PM
    Aztec120
    Aztec120 The Road To Hell Is Paved With Stock Tires
    Cisco
    Milwaukee
    La Tortuga '17 SR5 DCSB
    Leer Topper 90% Chrome Delete
    That was just for my 120k service I did myself a couple months ago. Did as much of a flush as I could through the cooler lines and without a techstream or any of that it was the simplest way to make sure I was at the right amount at the end.
    Just mentioned it because that's the only time I could think of that I poked around the OBDII. Still don't think that could have cause enough damage to cause the power loss to pin 16. At this point I'm just going to find a closer 12v source and wire that into it. Just to get emissions out of the way at least.
    I need to get out of the city and away from these emissions hijinks. Don't even get me started on the wheel tax o_O
  4. Jan 27, 2024 at 5:12 PM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
  5. Jan 27, 2024 at 5:23 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    The RCI bumper has little plastic bits that pop out to allow rear sensor placement :D although I think that's only for the parking warning and not the actual blind spot, I'm not 100% sure because neither of my trucks have the sensors.
    Don't need Techstream for a transmission service. But props to you for figuring out a way to do it yourself instead of spending 300 bucks at a dealership.
    For everyone else following along if you do a drain and fill you only get about a third of the fluid out. However, drain and fill is super easy and you can do it once a year for increased longevity of your transmission, it's fluid and it's constituent components.
    OldSchlPunk[QUOTED] likes this.
  6. Jan 27, 2024 at 5:29 PM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    yes
  7. Jan 27, 2024 at 5:37 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Yeah, they're separate sensors. The BSM fit in the corners of the bumper. AFAIK, nobody has come up with a setup that doesn't interfere with the radar. There's a member that had been trying to place the sensors in brake light housings, but he hasn't posted any progress in quite a while.
  8. Jan 27, 2024 at 5:45 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Derik, you got yourself a sale. Your product was still pricier than others I've looked into, but I like the design. I look forward to putting it to the test!
  9. Jan 27, 2024 at 7:16 PM
    Shellshock
    Iowa
    There’s someone that makes one but now I can’t remember who it is. C4 made one for a while but stopped.
    CygnusX191 likes this.
  10. Jan 27, 2024 at 7:19 PM
    drtfabrication
    drtfabrication Well-Known Member
    Derik
    Thank you ! It will ship out Monday or Tuesday :thumbsup:
  11. Jan 28, 2024 at 4:34 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    The hitch skid topic got me looking at the clearance of the underside of the bed.
    The hitch certainly messes with the natural flow if things..
    Look at all that room without the spare. lol
    You can use me as a reference of fluid film focal points. ;)
    8 yrs no underbody treatment. You can see where the rust starts...the welds and bolts mostly.
    the axle on the backside of the wheel gets it hard. (the square part).
    sparkystaco and CygnusX191 like this.
  12. Jan 28, 2024 at 4:48 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Yea... but you have to drive it in the winter. Just say'in. One garage princess to another... (Mine spends most winters in the garage dreaming of places to go.)
  13. Jan 28, 2024 at 4:55 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    The leaf springs weren't as bad as I'd expected. mainly the edges and exposed surface. (bottom more than top) had some light surface rust that cleaned up. :itllbuffout:
    What the image shows is dry rusty water from cleaning.
    I'll get something on it this year.
    The princess is looking more and more like the ugly stepsister.
  14. Jan 28, 2024 at 9:12 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Today's task was fixing the pull start on the snowblower. Thankfully I've only had to use it once. I've been dependent on the electric start so never bothered fixing the pull start.
    My property has no blvd. Sidewalk right to street. After many years of the plow guy throwing snow back onto a freshly clean sidewalk, they now leave about a car widths in the street.
    At least the sidewalk stays clean, I guess. Anyhow I clean up the few passes the plow leaves in the road.
    The 1st and only time I used the snowblower and I hit a big chunk of road ice. Locked up the auger and killed the engine....
    No pull start. Shit!
    Of course, it has to always be furthest from the garage.
    Had to drag it all the way back.
  15. Jan 28, 2024 at 10:32 AM
    Pixeltim
    '15 Black DCLB SR5
    I wonder if we have the same snowblower! I think the pull start on mine lasted for about 5 starts. I’ve been using the electric start ever since. It’s been several years now.
  16. Jan 28, 2024 at 12:40 PM
    Tim v
    Tim v Well-Known Member
    Tim
    SE. Wisconsin
    2014 White Tacoma access cab
    I kept on breaking the rope on mine, so I left the cover off and started it with my 38 year old "electric" drill brand new cordless wouldnt turn it. I fixed the rope this year with a Amazon.com: Diamondgrip Large with 92 Inch by 3.2 mm Unbreakable Gas Engine Pull Starter Recoil Replacement Cord Kit with Silver and Black Grip : Patio, Lawn & Garden no more problems before I was going and buying a generic rope from the big box or Walmart, tiered of dragging back to garage
    Sucked i a piece of tarp now waithing on a new gearbox to put in striped the brass gear driven by the worm gear, shear pins didnt work/fail
  17. Jan 28, 2024 at 1:05 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I mean, he can't just magically push it.... Elsewhere. Lol
    bkhlrTaco's[QUOTED] likes this.
  18. Jan 28, 2024 at 1:32 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Meet the newest edition to our automotive family:Elvis
  19. Jan 28, 2024 at 2:21 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Nice ride...
    I stopped making fun of minivans in 2018 when I had to use one for a loaner.
    Frickin' sweet! Huge open concept. T.V that dropped from the ceiling.
    Push a button and all the doors open.
    Like riding in a spaceship.
    CygnusX191, Spadi_5 and sparkystaco like this.
  20. Jan 28, 2024 at 2:25 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Turns out city ordinance states any snow put on the sidewalk by the city must be removed by the city. Once the plow guy was informed of this he stopped.
