Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Feb 26, 2024 at 2:34 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Crossmember to support the spare?
    CygnusX191, wi_taco and bkhlrTaco's like this.
  2. Feb 26, 2024 at 2:47 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Since I see gloves and helmets.
    Taking a break.
    Texting each other.
  3. Feb 26, 2024 at 2:50 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    That makes most sense other than maybe running to get the bags of lye to put by the scary axe and shovel.
  4. Feb 26, 2024 at 2:52 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Does lye remove blood stains?
    Aztec120 and CygnusX191 like this.
  5. Feb 26, 2024 at 2:57 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    If you gotta ask!
  6. Feb 26, 2024 at 3:02 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    among other things
    It is used in soaps, so I suppose it might.?
  7. Feb 26, 2024 at 4:36 PM
    WBTaco
    WBTaco To be determined
    West Bend, WI
    2023 TRD Sport DCSB MGM
    None
    Your projects are starting to sound like some of my projects.
  8. Feb 26, 2024 at 5:40 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    That my Taco brethren is the long forgotten crossmember so I can make/install the skid for the transfer case. The little stamped metal thing Toyota put on there is all smashed around the case. It will now have a solid 1/4 plate. I haven't done the exhaust move/reroute yet, but that is smashed to a nice oval that hardly interferes at all...
  9. Feb 26, 2024 at 5:46 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Did some wiring after work today. Added a light for the rear storage area
    Also going to add some more ground/rock lighting that I picked up a while back. Cool units that are magnetic… so no need to hard mount them. Need a couple out front. Couple more under and then a couple more in back behind the axle. Not there yet but you can see the dark areas. Looking forward to the light!
    Notice the scary ax illuminated on the rack?
  10. Feb 26, 2024 at 5:59 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    My t case cross member is custom .
    Custom smashed.
  11. Feb 26, 2024 at 8:15 PM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    Axes are very frightening!
  12. Feb 27, 2024 at 9:29 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    There is 1 less deer running around Wisconsin.
    A doe committed Rav4 suicide last night.
    The wife was coming to pick me up from work when this happened.
    Bumper, grill, headlight, upper radiator support appears to bent in. The hood still opens/closes. No fluid leaks.
    sparkystaco, CygnusX191 and wi_taco like this.
  13. Feb 27, 2024 at 9:37 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Son of a Bitch!
  14. Feb 27, 2024 at 9:44 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Dang that sucks, hope you & the wife are OK. Rav4 took it like a champ. Honestly impressive how little carnage there is, I feel like I see Tacomas crumpled into beer cans from deer impacts (lots of factors of course but our Taco front fascias don't seem all that robust especially now that I've taken mine apart a few times).
  15. Feb 27, 2024 at 9:49 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Damn, Dan. You should've shot it back in November.
    Did she get it slowed down some before impact, or full speed?
  16. Feb 27, 2024 at 9:54 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    They're supposed to crumple. Helps with absorption of the impact. All modern vehicles are like this.
  17. Feb 27, 2024 at 10:01 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    She was doing 35-40. It came up out of a ditch by the 151 overpass, almost in the city limits.
  18. Feb 27, 2024 at 10:06 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    I'll remember that next fall.
    Shooting costs less than hitting them.
    :infantry:
  19. Feb 27, 2024 at 10:09 AM
    wi_taco
    Adam
    SE Wisconsin
    Yes I am aware. My point was that the RAV4 seems to have held up better than our trucks which is surprising but not so surprising once you see how much plastic and very thin sheet metal are around our grille area. Even the crash bar looks to be more substantial on the RAV4 in Dan's photo compared to our aluminum unit on the Taco. Impressed by it's design is all.
    Camerasandcoffee and sparkystaco like this.
  20. Feb 27, 2024 at 10:18 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Bummer... My wife has had two deer and a logtruck take her on since we have been in WI. The Sienna lost every time. Hope she is okay.
