Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Mar 3, 2024 at 5:09 PM
    Stoney Ranger
    Stoney Ranger Pizza Cutters, Baby... and Lockers? Pffft
    Dave
    Driftless Area
    '18 Nauti Blue 4Runner SR5
    Full Armor-F/R Bprs Winch-ALF-Stickers
    Touche', sir. Touche'.:rofl::rofl::rofl:
  2. Mar 3, 2024 at 5:29 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Wonder why? There isn't a press issue, they just bolt up.
  3. Mar 3, 2024 at 5:38 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    From what I have gathered the theory seems to be once you loosen the big boy axle nut that gets torqued to 173 ft pounds, do a little banging on it to get it out from the spindle and then bolt it up to the new one and re-torque that big axle nut it's enough abuse to shorten their lives (A big part of that from what I understand is people seem to over or under torque the axle nut) again this is all just things I have read over the years on the forums who knows how much truth there is
  4. Mar 3, 2024 at 5:53 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Cygnus can say more, but in my experience, once you loosen that nut the damn thing almost falls out. Just wondering if the welding process induces a twist or other problem that can cause the problems. Having just put in new NSK's I am hoping for a long happy bearing life.
  5. Mar 3, 2024 at 6:19 PM
    Shellshock
    Iowa
    Most people probably don’t get it tight or just give it the ugga duggas
    I believe if it’s under tightened you get all kinds of weird things that start to happen
  6. Mar 3, 2024 at 6:23 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Yup, well played!
  7. Mar 3, 2024 at 6:27 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I'd like to know more about this, willing to bet there is a big steel shackle on the end that went thru the shield!
    The reason soft shackle's have replaced steel!
    This is the exact reason kinetic ropes have become so popular if they break they just drop they don't store energy!
    CygnusX191 likes this.
  8. Mar 3, 2024 at 6:31 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    That rug is going to be hard to vacuum.
    CygnusX191 and wi_taco like this.
  9. Mar 3, 2024 at 6:31 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Warping the housing is a very real possibility that may be hard to see.
    Aztec120, sparkystaco and CygnusX191 like this.
  10. Mar 3, 2024 at 6:48 PM
    Shellshock
    Iowa
    Nope. The soft shackle broke. He covers it in the video
    if you don’t have a radius on the recovery point, you can pretty easily break a soft shackle. Most recovery points have a 90 degree edge and you need to use a shackle.
    also a kinetic rope stores energy.. that’s what kinetic means. It’s like a big rubber band and you need the right size for the weight of the vehicles. Bigger isn’t better in that scenario as it won’t stretch like it should.
    Synthetic winch lines will usually just drop compared to steel cable. Totally different thing.
  11. Mar 3, 2024 at 6:50 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I would lean towards under-torquing.
    My wrench goes to 150#'s and I had a hell of a time getting it to that.
    150#'s is a lot.
    Getting the axle in and out causing reduction in the life of the ball joint sounds like overthinking hog wash to me.:blahblah:
    I must've had the axle bound at 1st because the nut got real tight shortly after the cotter pin hole.
    Couple days later the brakes were getting spongy. (rotor was pushing the pads out because nut was too loose).
    Took it back apart and got quite a few more threads out of it.
  12. Mar 3, 2024 at 6:53 PM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    It was the soft shackle that failed.
    And, kinetic ropes are like giant rubber bands, which is why they're dangerous. Regular straps are actually safer when used properly. The issue is when people try to use them like a kinetic rope.
    Edit: looks like @Shellshock already covered it.
  13. Mar 3, 2024 at 6:58 PM
    Shellshock
    Iowa
    Yeah. Tow straps are for slow pulls, not yanking. Things go seriously wrong in a hurry trying to use them like a kinetic rope.
  14. Mar 3, 2024 at 6:59 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    They have a whisky named after that fella.
  15. Mar 3, 2024 at 7:14 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Yup, he was wrong thinking that the soft shackle didn't cut because the sheath wasn't cut. Those hard edges put way too much pressure in a very small area. The rope was cut without cutting the sheath.
    Taking a 20' run on a kinetic rope is just asking for trouble.
    Listening to him repeatedly call a recovery point clevis was driving me nuts.
  16. Mar 3, 2024 at 7:14 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I bet you 200% it's not the wheel bearing so much as the axle.nut not being run in far enough/at the right torque. Use a wire brush to clean those threads off before you run the nut back on and heck, use it to clean the exposed threads off before you back. The nut off. Preparation goes a long way towards clean work. Highly recommend doing this. Especially for those of you whose wives drive CRVs and RAV4s. This will save your bacon.
    Idk. The whole auto mechanic word is.... Shit. Warranty pay is criminal. Flat rate is criminal. Every single owner is a money grabbing asshat. I like the work. Hate the management. Only bright side is three other people are quitting on Monday, and their shop Foreman who had $6 an hour taken from him and his title because they don't need that service anymore is putting in his 2 weeks. As soon as he hears back from another dealership. He's done with their crap and he's been with them for like 15 years.
    Shellshock knows all
    People who fuck up ball joints doing repairs to other components are missing the 17mm nut/bolt combo that attaches the ball join assembly at the bottom.
    Take
    That
    Off
    Life is so much easier when removing CVS and spindles and whatnot. And nothing breaks that way.
    Anywho.... Hope y'all are rocking in the free world. The discussions in here are something I look forward to everyday
  17. Mar 3, 2024 at 7:50 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
  18. Mar 3, 2024 at 7:56 PM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
  19. Mar 3, 2024 at 8:14 PM
    Shellshock
    Iowa
    The best shops seem to be the ones that are just a couple people working there
  20. Mar 3, 2024 at 8:16 PM
    wi_taco
    Adam
    This one has these mysterious stickers on it that say "SEARS". I think that means it's an antique, that's worth something eh?
