Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. May 4, 2024 at 4:06 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    How often do they get used?
    sparkystaco, CygnusX191 and Pixeltim like this.
  2. May 4, 2024 at 4:13 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
  3. May 4, 2024 at 5:14 AM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    Well, I also have an iceboat… :boink:
  4. May 4, 2024 at 5:48 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    So true.
    Speaking of stuff. If I remember correctly your running 32in tires. I have a 255/75/17 Hancock Dynapro At mounted on a stock 17in steel spare, 0 miles.
    If you need a full size spare let me know.
  5. May 4, 2024 at 6:03 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    We all found out in my 1st month here that I don't know what a steel spare is.
    o_O
    When I figure it out I'll reach out to you 1st.
  6. May 4, 2024 at 6:15 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    The whirlybird burns about a gallon a minute…but we can do 152 kts so it kind of evens out
  7. May 4, 2024 at 6:39 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Here's my battery back-up.
    10k mah Anker. Plugged into center console adapter. Charges when truck is on.Screenshot_20240504_083257_Gallery.jpg
    Who needs a fridge,
    I could go a couple weeks on Beef Jerky, Granola Bars, Water and Westsoy.:D
    sparkystaco, Pixeltim and CygnusX191 like this.
  8. May 4, 2024 at 6:43 AM
    Shellshock
    Iowa
  9. May 4, 2024 at 8:28 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Still got mine. That's the #2 "value" one that I won't let go. Did some custom bridgework with a badass2 and ebony wings.
  10. May 4, 2024 at 8:30 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    OldSchlPunk likes this.
  11. May 4, 2024 at 8:34 AM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    This is an aux battery setup...it's enclosed in a battery box. Full sized group 27 AGM. With a built-in DC/DC charger. Your fridge will likely have a cigarette plug for power.
  12. May 4, 2024 at 11:08 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    All summer long! Except the kayaks. I dislike them so I avoid those
  13. May 4, 2024 at 2:00 PM
    Stoney Ranger
    Stoney Ranger Pizza Cutters, Baby... and Lockers? Pffft
    Dave
    Driftless Area
    '18 Nauti Blue 4Runner SR5
    Full Armor-F/R Bprs Winch-ALF-Stickers
    Yep. that is exactly what I am doing. Thanks for that diagram. I thought the fridge could be direct wired (with a fuse) to the aux bat, but I wasn't sure.
    Right now I'm planning to install a fridge only. I have a much better understanding how this all works. If I went with a distrib. block, it seems to me that adding a bunch of stuff later should be relatively easy.
    There is a rubber plug in front of the passenger seat to fish a line through the firewall. I'll probably use 6 ga wire as that is what came in the REDARC kit.
    I just checked a couple of vids and this is a lot easier to install than what I am doing now. There's only 3 wires to connect. I would have to cut the connectors so that the battery cables could be fished through the firewall from the engine bay to the cabin. It would be a major PITA to fish them from the inside to the engine bay. Thanks for the link, Rich. My main concern is the space this set up takes in the cargo area. With just the wife and me, it's not a problem. When we have the grandkids, the coolers have to go on the receiver rack. I need every square inch of cargo space available, and this Kick-Ass box does take up some valuable real estate.
    A distribution block would make a lot of sense, but I have precious little room. I am struggling to figure out how to fit/mount everything under the hood as it is.
  14. May 4, 2024 at 2:25 PM
    OldSchlPunk
    Rich
    East Central Wisco
    I thought of that after I posted. I would thing your controller and something like a Blue Sea distribution panel could be mounted near where I'm thinking your battery is going to live under the hood. Something like this doesn't take up much real estate: https://www.amazon.com/AUTIDEFY-Fus...wer+distribution+block&qid=1714857717&sr=8-54
    That KickAss box works for me, because I have most of the bed to work with and can reside under my bed platform.
  15. May 4, 2024 at 3:22 PM
    Stoney Ranger
    Dave
    Driftless Area
    If I had the space, I'd definitely get the Kick-Ass. Easy to install, portable, you can put it on the shelf when you get home, multi charging ports. Checks some boxes I hadn't thought of.
    Aztec120, CygnusX191 and sparkystaco like this.
  16. May 5, 2024 at 9:44 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    So a decision has been made. Notice to difference that the word made versus reached implies... In a double team end run around my wishes, a decision about our future home has been made. For you all in Wisconsin, it may be a good or sad decision. So what is it you ask? Northland College has enough money to make next year work. The future is perilous at best for the school beyond that. No sure thing in life, and certainly no economic security. As such...We risking all and are staying in Wisconsin (for at least two more years.)
    I really loved the place we looked at in Virginia. Huge step up, I think, for me professionally. Same BS problems etc. etc. but a huge WOW! Oh, well... back to the salt mines.
  17. May 5, 2024 at 2:55 PM
    rubbersidedown
    rubbersidedown Well known voider of warranties
    Dean
    WI
    2020 Tacoma TRD OR Long Boi Voodoo Blue
    I, for one, am happy to hear that you'll still be "local" a bit longer! Of course after TWArk I know I'd meet up with you to play anywhere. Congrats on making a hard decision.
  18. May 5, 2024 at 2:57 PM
    rubbersidedown
    Dean
    WI
    Speaking of TWArk, I did my 5 wheel tire rotation today. Pretty obvious which tire was under the truck through the Ozarks.
  19. May 5, 2024 at 2:58 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Time to go get the other 4 muddy again :D
  20. May 5, 2024 at 3:38 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    That had to be a hard decision to make. Glad you'll be around for a bit longer. Looking forward to at least 2 more years of following you down a scratchy trail.
    :mudding:
