Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Jun 24, 2024 at 9:27 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I agree.
    CygnusX191 and Pixeltim like this.
  2. Jun 24, 2024 at 10:57 AM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    Fair? No way, that's like free if you ask me!
    Garages mark stuff up a ton more than that. Some people are so freakin cheap. It blows the mind.
  3. Jun 24, 2024 at 11:05 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    They don't want to because it's money out of their pocket. My local guy explained to me that I can buy the same part as him at NAPA, but he gets a shop rate and charges me retail. Then, if it's the wrong part, he loses time while he has to have the correct part delivered, screwing up his schedule. Now he has customers upset that he isn't getting to their vehicles in a timely fashion.
    This came up when, like you, I bought parts intending to do the job myself and found that I couldn't. I told him to charge me a little extra shop rate to cover the loss in parts $, and it wouldn't happen again.
  4. Jun 24, 2024 at 11:09 AM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
  5. Jun 24, 2024 at 11:15 AM
    Gearhead223
    Gearhead223 Well-Known Member
    22 Grey Tacoma TRD Off-road
    None so far
    I've been busy today! The air compressor was installed and wired by midnight and went to sleep. At 6:30am I woke up and started the bumper and winch install and now I can't figure out how to wire it to my auxbeam to turn it on and off....
    I'm just waiting on parts to plumb the air compressor and next week she gets taller
  6. Jun 24, 2024 at 11:17 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I suppose, liability as well?
    Who'd want to be responsible for putting on a part that you really are unsure if it's actually ok?
    The tire shop was sketchy about changing my tires with the wheel spacers on.
    I just told them flat out I won't hold them responsible for anything that may occur.
  7. Jun 24, 2024 at 1:39 PM
    McSpazatron
    McSpazatron Well-Known Member
    A lot of customers don’t understand that part selection is an actual service a good mechanic provides. The mechanic will get the blame if a crappy part fails early. I think it’s totally understandable why mechanics would be hesitant on allowing customer parts.
  8. Jun 24, 2024 at 2:38 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Well, I didn't get stickers today...
    ...what I got was another project.
  9. Jun 24, 2024 at 2:56 PM
    Stoney Ranger
    Stoney Ranger Pizza Cutters, Baby... and Lockers? Pffft
    Dave
    Driftless Area
    '18 Nauti Blue 4Runner SR5
    Full Armor-F/R Bprs Winch-ALF-Stickers
    Not sure what the process is installing those.
    1) Jack up vehicle. Support with jack stands.
    2) Support the axle, then adjust to find the sweet spot to take the stress off of the spring pins/bolts and U-bolts.
    3) Unbolt and hammer-out the U-bolts.
    4) Remove or hammer-out the spring pins/bolts.
    Or do you leave the tires on the ground and find the sweet spot by jacking the truck up and down? I've never done leafs before. At first glance it seems pretty straight forward. Add in the stuff you don't want to move and what it weighs ( the axle comes to mind ), there's more going on than meets the eye.
  10. Jun 24, 2024 at 2:58 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    Oh mannnn. Incoming 4+ inches of lift lol.
  11. Jun 24, 2024 at 3:06 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Never did leafs before. I'm assuming set the truck on stands. Take tires off. Put jack under diff. Remove u-bolts on one side, set bump stop aside. Unbolt/cut/hammer the sh$t out of the bolts on old leafs. Lower axle a bit to give leafs room. Remove old leafs. Install new leafs. Install new axle shims. Jack axle back up. Install u-bolts/bump stops. Repeat on other side. Remount tires. Set truck back on ground.
    What could possibly go wrong?
    Somewhere along the way, I will need to determine if/how much I have to shim the carrier bearing.
  12. Jun 24, 2024 at 3:11 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    There's a bracket that hold the brake line to the leaf pack and front shackle mount that will need to be removed so the brake line doesn't stretch.
    Depending on the new leaf pack, you may or may not be able to put the leaf pack bracket back.
    With the aal I had to zip tie it...
    Still holding.
  13. Jun 24, 2024 at 3:13 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    1° of shim/ 1" of lift is a good place to start.
  14. Jun 24, 2024 at 3:20 PM
    OldSchlPunk
    Rich
    East Central Wisco
    I would hope not. The specs call for 2" of lift with a load capacity of 440#. I already have an add-a-leaf, which is giving me about 1/4" or so above the flat stock pack, but without my camping gear, I'm hitting the bump stops on all but the smallest of bumps.
    Dean @rubbersidedown says his settled in nicely and with my cap and battery in the back, I would expect I should gain about an inch? Plus, the spring rate should be more progressive.
    Dan @Taco-Grinder, I guess I'll be making arrangements to get your packs back one day.
    Pat @pearing, they aren't Alcans, but I couldn't pass up the price. Being a poor, retired trucker, I have to pay more attention to my budget. :rofl:
  15. Jun 24, 2024 at 3:26 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    Iron Man quotes for lift are always super conservative. My Nissan frontier springs they claimed 2 in and they were every bit of 3 in and it seemed more like three and a half. Also lots of guys in the iron Man thread on here got way more lift than claimed out of both the front and rear
  16. Jun 24, 2024 at 3:27 PM
    Camerasandcoffee
    Camerasandcoffee 900hp short of 1000hp
    Jonathan
    Racine WI.
    2019 Trd Sport
    Relentless Fab hybrid bumper, 2.5” Dobinsons IMS lift, RCI skids and sliders, block heater. Painted FJ Steelies. Was trying to keep it stock, now slowly building for the Wisconsin trails.
    Those are nice springs though. I know @rubbersidedown likes his.
    it’s actually pretty straightforward you just need to be aware of the loads you are playing with.
    I jacked mine up high enough to let the back axle full droop and support with jack stands at the frame. If the new springs have greater arch you may wait Jack the truck up higher so you are not fighting the springs later.
    Support the axel on another set of jack stands. A little bit lower is fine. You can use the jack to raise or lower each side as needed. Watch the brake lines.
    undo the u bolts and free the axle then work on the shackle bolts and the front bolts.
    put in the new springs on in the reverse order. Using a ratchet extension can help getting things aligned so you can ouch the bolts into the bushings. Mount up the axel loosely and push it full forward. A ratchet strap on each side pulling forward helps. This keeps it square to the frame.
    I’m a big fan of getting everything bolted in place loosely and tightening and torque once everything has found its home once the truck is back on the ground especially bushing bolts. I usually jounce the suspension first.
    it’s actually not too bad. Worst part for me it the getting down and back up. I’ve seen some pretty scary videos where people didn’t stop to think things through and dropped axels or had the truck move on the jack stands.
  17. Jun 24, 2024 at 3:28 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    With leafs, do one side at a time
    OR
    Unbolt the shocks.
    See how one shock mounts to the rear of the axle, and the other to the front? That'll twist the axle the second you get both leaf springs off. :D
    In other news...
  18. Jun 24, 2024 at 3:36 PM
    OldSchlPunk
    Rich
    East Central Wisco
    I get where you're coming from. How much constant weight did you (or the others in the Ironman thread) have on the springs? With none of my camping crap, I'm probably 300# over stock...every day.
    There are guys that say Alcans aren't what they were 3 years ago. Others say OME flatten out too soon. Blah, blah, blah, blah.
    I'm here, don't have much choice, did a bunch of homework. The chips will fall where they fall at this point.
  19. Jun 24, 2024 at 3:39 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    My frontier had very minimal weight added to the rear and as for guys getting more lift than expected everybody had all kinds of setups. I would say you should expect 3 in for sure and probably more at first until it settles.
  20. Jun 24, 2024 at 3:40 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    Speaking of leaf springs I feel like stage 2 would be better for me on my RXT leaf springs but I'm too lazy to change it lol.
