Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Jun 26, 2024 at 9:31 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Been thinking about this...
    When I originally put in a block (gasp) the retailer recommended a 1* shim, so I did. As my suspension has evolved, I kept the shim in the rear. Now, with these springs, I would suspect the relationship of the axle to the frame will be greater than stock and the angles of the driveshaft will change. Will I need to change the pinion angle? Who knows.
    Shims, whether needed or not are easy enough to change or remove if need be. Shims (which I've made out of bar stock I have laying around) for the carrier bearing would also be easy enough to install/remove.
  2. Jun 26, 2024 at 9:55 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    What's weird, to me, is I bought my truck 2 yrs used.
    When I did the lift, I noticed it already had shims at stock height.
    Is that normal? Did the previous owner have it lifted and left shims in after removing it?
    After I bought it I mentioned to the dealer about a d.s. vibe "that they couldn't hear". ya.
    I know now it was the needle bearing.
    I left the shims in when I lifted it. Afterwards when I measured the angles, everything was good.
    I never measured before the lift but I'm thinking my driveline angles had to be off at stock height when I bought it.
  3. Jun 26, 2024 at 10:01 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    fwiw i would be skeptical of significant vibes at stock/near-stock height considering the number of trucks pulling +15" of travel in the rear on SUA/linked setups and having minimal issues. shim it if you want/if you have big changes in pinion angle. I'd think its probably not a huge deal though.
  4. Jun 26, 2024 at 10:21 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Not hearing or feeling anything doesn't necessarily mean there isn't a problem, yet.
    U joints will operate outside the working angles but for how long?
    I just assume make sure they're within the 1-3°.
  5. Jun 26, 2024 at 12:30 PM
    rubbersidedown
    rubbersidedown Well known voider of warranties
    Dean
    WI
    2020 Tacoma TRD OR Long Boi Voodoo Blue
    Damn Dan! Might be time to stock some fish in some of those ponds. Hope it dries out soon for you.
  6. Jun 26, 2024 at 12:33 PM
    rubbersidedown
    Dean
    WI
    Got home to a package that certainly reminded me that it's time to get busy correcting the TWArk buff. No more excuses.
  7. Jun 26, 2024 at 6:19 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    I've got Bluegills and Bullheads. I've seen perch but not for long time.
  8. Jun 27, 2024 at 3:54 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I don't mess with them but I hear bullhead is good smoked.
  9. Jun 27, 2024 at 3:56 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Quoting my own post.
    PB Blaster lasted about a day. @CygnusX191
    Hit it with the fluid film last night.
    So far so good.
    My mother always said I don't listen very well.:D
  10. Jun 27, 2024 at 4:33 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    To be fair, my ideas are good like.... 1 out of 20 times :anonymous:
    I used to work with a Chevy guy who put like, an entire tube of red tacky grease on either side, just jacked his truck up every Sept and slathered it all over the leaves and in between.
    Made a royal fucking mess.
    But
    It made it easier to hear his valve ticking :D
    Edit: his leaves were messy, but rust free. But he would never treat his frame. Weirdo
  11. Jun 27, 2024 at 4:53 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    As a kid mom would would fry them.
    It's a small pond, maybe 1500sq feet and deepest spot normally is 8ft. Fish don't get real big. I feed them because that's what old folks do.
  12. Jun 27, 2024 at 10:18 AM
    Gearhead223
    Gearhead223 Well-Known Member
    22 Grey Tacoma TRD Off-road
    None so far
    Well Thanks to Adam my front struts are assembled after he let me use his spring compressor and new tires have been ordered. The first week of July and my truck will be almost fully done and then I'll be off for 6-7 days in the U.P.
  13. Jun 27, 2024 at 10:45 AM
    OldSchlPunk
    Rich
    East Central Wisco
    Filled up with gas this morning and confirmed...I'm getting over 1mpg better mileage with these tires. :D
    Maybe tackle the leafs tomorrow.
  14. Jun 27, 2024 at 11:07 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    FIFY
  15. Jun 27, 2024 at 1:13 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Negative. With the lift in the rear, I should get better mileage...I'll be going downhill all of the time!:rofl::facepalm::der:
  16. Jun 27, 2024 at 1:13 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Glad I could help by having the right tools. And nice to officially meet you, good luck with the lift and enjoy your time off in the U.P. :thumbsup:
  17. Jun 27, 2024 at 1:29 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Was out earlier in the Killsnake Wildlife Refuge to check out the high water. Was there on Mon and drove through, there were spots where the gravel wasn't covered in water, the rest was 4-8" deep, followed a Chevy through in case he got stuck. Today, it's worse. Water was never less than 4" deep, most places were 8-12". There were Ducks and Egrets hanging out on the road, because that was the shallowest spot. At one point, the Egrets jumped up and flew about 100' or so down the road and set back down. When they jumped, I could've swore a fish jumped! Sure as hell, I slowed down and there were a couple of Bass next to me. Wish I could've gotten a picture...should've thrown a line out the window.:D
  18. Jun 27, 2024 at 2:59 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Good point.
    That would make a good campfire debate.
  19. Jun 27, 2024 at 3:00 PM
    Aztec120
    Aztec120 The Road To Hell Is Paved With Stock Tires
    Cisco
    Milwaukee
    La Tortuga '17 SR5 DCSB
    Leer Topper 90% Chrome Delete
    Anybody hurting for an Amazon front bumper special? Says it's steel. If I wasn't looking at suspensions already I'd probably bite. edit: forgot some of you dont do the facebooks.
    $200 Appleton,WI
  20. Jun 27, 2024 at 4:00 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    It appears Rich has thought this one through.
    :blahblah:
