Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Aug 3, 2024 at 3:40 PM
    rubbersidedown
    rubbersidedown Well known voider of warranties
    Dean
    WI
    2020 Tacoma TRD OR Long Boi Voodoo Blue
    When at the track, cart pose. Kenda 20s baby!
  2. Aug 3, 2024 at 3:49 PM
    McSpazatron
    McSpazatron Well-Known Member
    Took the skid plates off and spent some quality time admiring and inspecting the 4runners undercarriage for any issues after the Colorado trip.
    No trip related issues or damage that I can see!
    I gave everything a general washout yesterday and today I greased up the driveline zerks and cleaned the driveshafts up a bit so they look pretty behind all the skid plates.
    While the skids are out, I touched up all the gashes and scrapes. Also drilled a few more drain holes in it
    This might need some attention before the next gear oil change…
    I won’t be able to get a socket on that drain plug until I figure out a way to clear all the metal that was gouged out all the way to the plug. I’m thinking a cold chisel to bend the that out of the socket hole area. Any other ideas? Pretty much ground out all the ring protecting the drain plug, so I’m gonna have to do something about that too.
    That looks a lot like the factory crossover on the 4runner! Expect your looks like is completely recessed. The 4runner has just a bit that hangs lower than the transmission crossmember. Looks good!
  3. Aug 3, 2024 at 3:58 PM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    Yeah, the first picture shows the original pipe, hopefully the shiny new one will do the trick.
  4. Aug 3, 2024 at 4:31 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I like that option.
  5. Aug 3, 2024 at 5:47 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I need to get a picture of mine in there. It comes back behind the transfer case before cutting over and joining a new y-pipe.
  6. Aug 3, 2024 at 6:43 PM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Having a relaxing evening at home. Got a little packing/rearranging done ahead of next weekend this evening. Not a bad way to spend a Saturday. :D
  7. Aug 3, 2024 at 7:13 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Yeah, all the solid axle swap stuff. You pretty much have to do links with how tight the space is on the drivers side of the SD60. Steering is easy with a Toyota box and weld on D60 steering
  8. Aug 3, 2024 at 10:30 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    No. no you don't. Nobody in the north chooses that option. :p
    Looking at both options I try to look at which one causes any flow restriction.....
    Flattening the pipe or adding another bend?
    Maybe nothing noticeable and maybe I'm overthinking that part but the outflow must change.
  9. Aug 4, 2024 at 5:06 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    My kind of night.
    Not indulging in finer microbrews or bourbons anymore is why I seek out finer single origin coffees.
    I don't mind a cigar every now and then but my knowledge stops at the occasional wood tips I bring fishing with me.
    For the sole purpose of keeping the bugs away from my face while it's clamped between my teeth.
  10. Aug 4, 2024 at 5:08 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    :rofl:
  11. Aug 4, 2024 at 5:33 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Sweet!
  12. Aug 4, 2024 at 5:47 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Please I would like to see that option. Will be doing this and putting the last section of skid on this fall
  13. Aug 4, 2024 at 6:07 AM
    Pixeltim
    '15 Black DCLB SR5
    I wonder if it’s possible to remove the cobbled pipe I now have an have a muffler shop duplicate it by bending one pipe and welding the proper ends on. I really like where it is, but it would be nice if it was cleaner.
    I found these here on TW.
  14. Aug 4, 2024 at 6:14 AM
    Thatbassguy
    James
    I'm definitely not any sort of expert. I usually buy cheap Backwoods cigars. Last weekend I was walking through the cigar booth at a Harley Davidson event with a friend, and decided to buy a few nicer ones. Then, I decided to get a little humidor to keep them nice, because I figured it would be awhile before I smoked them. Then, I decided to get a few more, and now it's become a whole new problem. o_O
    Even though I have no idea what I'm talking about, I will say that I liked the Padron more than any cigar I can recall. And, they're not terribly expensive, compared to what's out there.
  15. Aug 4, 2024 at 6:26 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    It is. I saw it somewhere. Can't remember where. If I find it again I'll show you. :D
    Glad I could help.
    Update: Are you referring to something like this?
  16. Aug 4, 2024 at 6:31 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    How much clearance to the drive shaft? I know you have no idea if it hits but I worry it could get there at full drop….
  17. Aug 4, 2024 at 6:38 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    No extra bends or flattening on mine :D
    bkhlrTaco's[QUOTED] likes this.
  18. Aug 4, 2024 at 6:47 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    So, are you going to crawl under there and get us a pic?
  19. Aug 4, 2024 at 6:58 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    When I see that exhaust make a vulnerable turn,IMG_2293.jpg I think of that '91 prelude you've heard me talk about.
    I caught the exhaust by the arrow.
    Everything in front got stretched out. Everything behind got crushed and pinched. Very costly snag having to replace entire exhaust.
    I like where Tim with 1 m has it.
  20. Aug 4, 2024 at 6:59 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    :anonymous:
