Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Aug 21, 2024 at 9:17 AM
    Shellshock
    Iowa
    A sharpener is super cheap and it takes like 5 minutes. I keep a spare chain in the box incase I ever need it.
    @Tigerian can tell you more about chainsaws and trees. He did plenty of that up in northern Minnesota for the DNR
  2. Aug 21, 2024 at 9:19 AM
    Shellshock
    Iowa
    I use mine all the time around the house. It’s plenty for occasional use.
    viar 400p is solid if you want a dedicated one for the vehicle. I mostly use my arb single these days. I’ve also got the twin but that one doesn’t get used much.
  3. Aug 21, 2024 at 9:21 AM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    But, but... this is a perfect excuse to do some custom wiring! You could add a proper plug in the bed, and add the corresponding cord end to the inflator!
    I'm trying to help! :D
  4. Aug 21, 2024 at 9:23 AM
    Shellshock
    Iowa
    This is a dc 12v compressor. The plug in the bed is ac 120v
    you can’t just put on a different plug.
    I’ll let the local sparky tell you why that’s bad.
  5. Aug 21, 2024 at 9:24 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    You've all been very helpful.
    My takeaway is yes it can be rewired and yes there are other options.
    @pearing I'll give you that $50 for it.
  6. Aug 21, 2024 at 9:25 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Ya I've established that.
    Get with the program. :blahblah:
  7. Aug 21, 2024 at 9:25 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    It wouldn't be too hard to run a fused 2 gauge (?) wire back and into the cubby with an Anderson connector (or whatever you come up with) for DC power in the bed. You would only need a couple of feet of ground wire, which could be bolted to the frame.
    There's a :spending::spending: solution to every lazy-assed (;)) problem out there. :boink::rofl::anonymous:
  8. Aug 21, 2024 at 9:26 AM
    Shellshock
    Iowa
    If you really wanna be lazy, you need a mounted compressor with a retractable hose.
    https://www.apexdesignsusa.com/products/compact-reel-system-crs
  9. Aug 21, 2024 at 9:27 AM
    Shellshock
    Iowa
    Just run power and a distribution block. Then it’s already there for when you finally decide to put in a fridge
  10. Aug 21, 2024 at 9:28 AM
    Shellshock
    Iowa
    Yeah I noticed about 3 posts later lol guess everyone is on tw today
  11. Aug 21, 2024 at 9:30 AM
    OldSchlPunk
    Rich
    East Central Wisco
    FTFY
  12. Aug 21, 2024 at 9:36 AM
    OldSchlPunk
    Rich
    East Central Wisco
    When I bought this saw, I bought 2 extra chains, because like guns 2 is 1 and 1 is none.
  13. Aug 21, 2024 at 9:37 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I have all that room where the spare was. Could mount it under there and have the hose come out where the spare hoist tool goes through the bumper! :D
  14. Aug 21, 2024 at 9:37 AM
    OldSchlPunk
    Rich
    East Central Wisco
    As you've seen, we're very helpful at spending your money!
  15. Aug 21, 2024 at 9:49 AM
    Thatbassguy
    James
    :yes:
    How many amps is an Anderson plug rated? The compressor is only rated to draw 30A. That should only require 10AWG. :notsure:
    This is the best idea yet!
  16. Aug 21, 2024 at 9:52 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    It's reassuring to know I have people I can count on. :rofl:
  17. Aug 21, 2024 at 9:53 AM
    OldSchlPunk
    Rich
    East Central Wisco
    Anderson plugs are rated at 50-175A. I knew you'd come up with the correct wire gauge off the top of your head, I'd have to look it up...feeble old mind and all.
  18. Aug 21, 2024 at 9:55 AM
    OldSchlPunk
    Rich
    East Central Wisco
  19. Aug 21, 2024 at 9:57 AM
    OldSchlPunk
    Rich
    East Central Wisco
  20. Aug 21, 2024 at 10:25 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
