Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Sep 20, 2024 at 3:33 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    For what it's worth, all the stuff I know now about 12V DC electro-pixies I didn't know before I set to task at building my 12V battery setup in the Tacoma. Many hours on Google and YouTube later and now I know enough to be dangerous. Once you know the basics it's not that difficult and shouldn't be feared. We can always help answer questions if you have them.
    That's a good way to put it. Keep It Simple, Stupid definitely applies to wiring as well. It can get complicated once you start doing tricky/cool things but it often doesn't need to except if you're getting fancy with it.
  2. Sep 20, 2024 at 3:37 PM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    And before you know it you're doing the real fun stuff!
  3. Sep 20, 2024 at 3:42 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Too funny, I had my head in some panels on the press today.
    Clutch button was being finicky.
    Looked at my 2nd pressman and asked him, how he'd like to be the one to wire that!!
    (I don't understand it but I can track things back and look for bad contacts, boards or relays, etc)
  4. Sep 20, 2024 at 4:16 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    CygnusX191 and sparkystaco like this.
  5. Sep 20, 2024 at 4:33 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    We always use little butane torches, we call them krack liters :rofl:
    about three in tall.
  6. Sep 20, 2024 at 4:59 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    That is what I have used for the last several years. Even in big wind or 10 below the stinker gets the job done.
    Aztec120, CygnusX191, wi_taco and 3 others like this.
  7. Sep 20, 2024 at 5:04 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Got my uniballs changed after work today. Relatively easy job that had big results-wow I had let them go too long. Truck is sitting higher and no rattlyklunk sheet or wandering (although that was minimal.) Had so much play that the tires were rubbing and I just thought it was normal. Unfortunately, I found that the other side boot let go this week. WTF! At least I know they are good for 100k or so. Guess I have another day under the truck ahead of me...
  8. Sep 20, 2024 at 5:09 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    That puller must've worked pretty slick.
    CygnusX191, wi_taco and sparkystaco like this.
  9. Sep 20, 2024 at 5:55 PM
    rubbersidedown
    rubbersidedown Well known voider of warranties
    Dean
    WI
    2020 Tacoma TRD OR Long Boi Voodoo Blue
    Insufficient Clearance is really good! <--- A sentence I never thought I'd utter.
  10. Sep 20, 2024 at 6:06 PM
    taoist
    taoist taoist
    Pete
    The Baraboo Range
    18 Sport ACLB
    Question for the group. About to change fluids and would like to know if anyone is running a lubricant other than Toyota SAE LF 75W in their transfer case?
  11. Sep 20, 2024 at 6:08 PM
    rubbersidedown
    Dean
    WI
    :popcorn:
  12. Sep 20, 2024 at 6:13 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    I use-SHOCKING-Amsoil...
  13. Sep 20, 2024 at 6:13 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Like a bomb!
    Edit: I meant to take a picture, but it went so fast I forgot...
    Aztec120, CygnusX191, taoist and 3 others like this.
  14. Sep 20, 2024 at 6:20 PM
    Supr4Lo
    Surprise, AZ
    Redline MT-90
  15. Sep 20, 2024 at 6:35 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Lucas 75/90 synthetic
  16. Sep 20, 2024 at 6:35 PM
    taoist
    taoist taoist
    Pete
    The Baraboo Range
    18 Sport ACLB
    Have Amsoil 75-90 in the other gear boxes but have read that nothing but Toyota lube must be used in the t-case. Is 75-90 what you are running?
  17. Sep 20, 2024 at 6:35 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
  18. Sep 20, 2024 at 6:49 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Amsoil 75/90. Second gen... know nothing about third gen
  19. Sep 20, 2024 at 6:53 PM
    Supr4Lo
    Surprise, AZ
    The 3rd gens call out straight 75W. The transfer case internals are the exact same as the 2nd gen. Most likely the 3rd gen uses a lighter oil to help hit the EPA MPG bs.
  20. Sep 20, 2024 at 6:58 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    This was my guess, but won't say unless I know... safer that way.
    Aztec120, CygnusX191, taoist and 4 others like this.
