Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Oct 18, 2024 at 9:03 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    So....
    Are hammer hangers and shackle flips harder on shocks then because of the further extension?
    sparkystaco and CygnusX191 like this.
  2. Oct 18, 2024 at 9:03 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    For my pig, it would help supplement!!!
  3. Oct 18, 2024 at 9:04 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Yes, would have to do links.
  4. Oct 18, 2024 at 9:05 AM
    Shellshock
    Iowa
    not if you have proper length shocks
  5. Oct 18, 2024 at 9:06 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    I was under the impression they fit stock? Hu. Need to call them.
    CygnusX191 likes this.
  6. Oct 18, 2024 at 9:06 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    This
  7. Oct 18, 2024 at 9:09 AM
    Supr4Lo
    Surprise, AZ
    Which shock were you looking at? I don't see a coilover that would fit in stock location.
    sparkystaco, wi_taco and CygnusX191 like this.
  8. Oct 18, 2024 at 9:11 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I ask because the 4xInno flips I was looking at will work with my Nitrochargers.
    That means I'm not using the full shock, now.
    Constantly using the full amount with a shackle flip or hammer. (Even at correct length)
    Seems like it would cause more wear.??:notsure:
  9. Oct 18, 2024 at 9:12 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    I think I am just being stupid... looks as if they are for 3 link. Be nice if I could double up though!
  10. Oct 18, 2024 at 9:13 AM
    Shellshock
    Iowa
    thats why you limit your travel to be less than the full shock travel. thats why things like bump stops and limit straps exist.
    bottoming out the shock on either end is a good way to blow it up.
  11. Oct 18, 2024 at 9:13 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Sounds like you need it.
  12. Oct 18, 2024 at 9:26 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I'm having serious deja vu in this thread right now
    Idk. I'm too poor for new stuff :bananadead:
    Bought some used Fox remote resis for my rear, they're definitely too stiff for my truck on the road, but they're $1300 shocks and I got them for $150.... Plus they're tremendous off road.
  13. Oct 18, 2024 at 9:32 AM
    McSpazatron
    McSpazatron Well-Known Member
    Wow, I would be pretty disappointed. I’m curious if you’ve experienced this…I’ve noticed that if I have one side of my rear axle getting a little pressure, and the other side drops off a ledge, the shock seems to extend instantaneously as if it had zero rebound damping. Rebound always feels fine when wheels are on the ground, but unloading them completely just lets them flick out with big loud CLUNK!
    Limit straps were suggested last I brought it up, but they seem extend so hard sometimes, I’d worry about pulling straps out the mounts lol. Have you noticed any of that? Mine are the IMS, not sure if the adjustables are any better in that regard. Maybe that’s what causes an early failure?
  14. Oct 18, 2024 at 9:34 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Limit straps are always the answer. Strapping and bumping to save your shocks is worth it.
  15. Oct 18, 2024 at 9:42 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Brake lines make terrible limit straps.
  16. Oct 18, 2024 at 9:43 AM
    McSpazatron
    Perhaps I’ll need to do that…. Seems kinda overkill for a daily driver, but all the secretaries at work would definitely know I wheel. The parking lot is unfortunately lacking in posing rocks, but I can find a curb or something :D.
    Since I have you on the line, do you have any thoughts on the best way to go about it? Are “blingy” kits fine for straps, or is that a custom build yourself type of situation?
  17. Oct 18, 2024 at 9:52 AM
    McSpazatron
    Thankfully, with my standard length shocks, I’ve verified that at full extension, brake lines are nowhere near getting pulled.
    That said, when I recently installed some heavier rate coils, I had to get the jackscrew bottle in there to spread the axle opening so I could shove the coil in. That definitely started to pull on the brake lines a bit. Didn’t seem to be too excessive at the time, but of course, after the fact, I felt guilt ridden lol. I’ll probably have to replace them the next time I’m in there to make sure they don’t collapse internally at the worst possible moment. My buddy had that happen to him (for unrelated reasons) on a front caliper hose. The line was deteriorated inside and actually blocked return flow, so it actually caused the calipers to “sieze”. Only found out it wasn’t actually seized until he cooked his brand new replacement rotor and pads lol. That forces us to look upstream and thats when we realized it was the flex line.
  18. Oct 18, 2024 at 9:55 AM
    Supr4Lo
    Surprise, AZ
    Just get the limit strap hardware and DIY it like a man.
    https://trail-gear.com/suspension/limit-straps.html
  19. Oct 18, 2024 at 10:03 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Did a thing! I a moment of madness I ordered some Locked Offroad adjustable Tundra rears... The guy I talked with wanted to listen and this is what he suggested. Out next week. Might have them on before @Supr4Lo gets to his... Remind me if this comes up in a year or so that I should have bought Ironman. Decals inbound
  20. Oct 18, 2024 at 10:05 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Well, I have some stock coilovers you can cut up for springs, if/when your fabricators get up to q.c. standards.
