Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Nov 7, 2024 at 1:20 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Ordered a gallon of Woolwax
    Hard-On to use on the shackle flip and hidden receiver.
    Says it's odorless and doesn't mention humidity for application, just temperature.
    So I'll brush it on down in the basement.
  2. Nov 7, 2024 at 3:43 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    If I only had a bed...
  3. Nov 7, 2024 at 3:45 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Humidity maters as it is water based and must dry. It is also not UV resistant and must be top coated. This is what I used as a base on the flat bed. turns rock hard so clean up well or live with it. Love it. Is not non odor despite what they say. Sprays well with an under coat gun
  4. Nov 7, 2024 at 3:54 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Thanks for the notes.
    I was hoping you'd chime in. I was going to rattle can the fr's then I remembered you used it on the flatbed.
    Those parts seem as good a place as any to use Hard-on or Steel-it but Steel-it is out of my price range for coatings.
  5. Nov 7, 2024 at 4:13 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    It will be fine for the application. Will take several days to get "hard" for topcoat. Don't let it get wet for a couple days and I would try and keep it closer to 60 degrees than 50. Make sore to use a Scotchbrite course pad (red) or like 150 grit to scuff it up for topcoat or it just won't stick. I had a lot of trouble getting rattle can paint to stay on. When I used catalyzed urethane I sanded with 150 grit and sprayed right over it-sin! Looks fine for what I do and it has so far stayed on.
  6. Nov 7, 2024 at 4:30 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I didn't buy nuthin....
    :anonymous:
    rubbersidedown and Cipher94 like this.
  7. Nov 7, 2024 at 5:48 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I was going to tap the amber chase lights right into the fog circuit to come on with the factory column switch.
    A coworker (who plows snow in the winter) tells me you can't have amber lights facing backwards on the street, so I guess I'll wire them separately.
    An FYI for anyone else not in the know.
    Aztec120, sparkystaco and CygnusX191 like this.
  8. Nov 7, 2024 at 6:31 AM
    Cipher94
    Cipher94 Well-Known Member
    Madison, WI
    2016 TRD OR
    time for more bad finnancial advice, time to replace my tires. I also want more of an offset. I'm not displeased with Ko2s 2nd gen, but I am curious about other options. I haven't had issues with noise or handaling, but them on at 5 years ago just before 44k miles and have put close to 70k on them. They are showing dry rot also.
    currently on 265/75/r16 and want to stay with the r16 but am interested in going to 285. Also have 2"/1.5 blocks as of now.
    tires are used in the city a bit, but my primary driving is state highways and the driftless area hills frequently in the winter and often before they get plowed. I would like to keep the aggressive look, but don't think I want a mud tire. recs? bonus points for pics of offsets but I'll be going to the other forms to also do some searching.
  9. Nov 7, 2024 at 6:51 AM
    rubbersidedown
    rubbersidedown Well known voider of warranties
    Dean
    WI
    2020 Tacoma TRD OR Long Boi Voodoo Blue
    Big fan:
    https://www.mickeythompsontires.com/light-truck-tires/baja-boss-a-t
  10. Nov 7, 2024 at 7:06 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    I will get beat on a bit maybe, but I recommend Kenda. More specifically the Klever. I ram KM3's for years and am a fan of BF Goodrich; however, the KM2's get nothing but bad lip service. I went with these on a recommendation from a fellow TW driver and I will never go anywhere else. They rock. Best snow tire I have had in years. Do everything well to above average. No tire does it all well, but for looks and performance based on what you say how they will used I think you should consider them.
  11. Nov 7, 2024 at 7:11 AM
    Cipher94
    Madison, WI
    2016 TRD OR
    how are they during the summer or in wet conditions and at speed?
    I'm not going to hate on them I am genuinley curious. I actually run kenda tires on my old mountain bike, new one came with maxxis and that will probably just be direct replacements. I also got to drive around on my friends truck maxxis a bit too.
  12. Nov 7, 2024 at 7:13 AM
    Cipher94
    Madison, WI
    2016 TRD OR
  13. Nov 7, 2024 at 7:15 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Coming from KM3's they are not as good in mud-to be expected. Drive on dry fantastic and are the quietest offroad tire I have ever owned. I have never felt in the edge running them on pavement in the wet. My truck is unique in that I have a pretty even 50-50 weight distribution so can't say how they feel on a light bed, but they are simply fantastic on wet roads in my opinion. Way better confidence wise than the old KM's made me feel. Never have they felt like they were on edge. They have been spun up to 90mph (down hill with a tailwind) and seem fine. That wasn't something I was worrying about, so says a lot.
  14. Nov 7, 2024 at 7:19 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    You can in Missouri
    Listen to the man
    Aztec120 and bkhlrTaco's[QUOTED] like this.
  15. Nov 7, 2024 at 7:20 AM
    rubbersidedown
    Dean
    WI
    Yep, running 285s on 16s now. BTW, offset comes from wheels more than tires. I wasn't going for more poke, but the aggressive side biters do stick out a bit. I picked up new Mickey Thompson wheels as well. 0 offset. I have a 2.5"-ish lift and get just slight rubbing on the mudflaps up front at the right turn and compression.
  16. Nov 7, 2024 at 7:28 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    I agree with Pat. Kenda Klever RT's FTW. Have had them in 33s, 35s, and now 37s. Most people overlook them because it's not a big name tire with a lage social media following.
  17. Nov 7, 2024 at 8:30 AM
    McSpazatron
    McSpazatron Well-Known Member
    Wait…37s? When did this happen?
    what load ratings have your kendas been
  18. Nov 7, 2024 at 8:35 AM
    Supr4Lo
    Surprise, AZ
    33s were E load
    35s & 37s ares D load
    37s are in progress. Just have to get an aliment and cut the fenders for clearence when stuffed.
  19. Nov 7, 2024 at 8:37 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Big curbs in AZ.
  20. Nov 7, 2024 at 8:52 AM
    Supr4Lo
    Surprise, AZ
    Getting to the mall is an adventure lol
